'div((nuEff*dev2(T(grad(U)))))' not found?
Old   January 6, 2024, 10:01
Default 'div((nuEff*dev2(T(grad(U)))))' not found?
Udit S Rao
uditrao04 is on a distinguished road
Hello!
I am a beginner in OpenFOAM and I have just attempted to complete an analysis by my own (using pimpleFoam/pisoFoam). I have created my own mesh (~10^5 cells) and have all the necessary calculations ready.
I filled the '0' folder files with the necessary initial conditions but while running pimpleFoam or pisoFoam, it gives me this error:
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
No MRF models present
No finite volume options present
Courant Number mean: 1.79393 max: 501.077
Starting time loop
Time = 0.5
PIMPLE: iteration 1
--> FOAM FATAL IO ERROR: (openfoam-2312)
Entry 'div((nuEff*dev2(T(grad(U)))))' not found in dictionary "system/fvSchemes/divSchemes"
file: system/fvSchemes/divSchemes at line 29 to 30.
From const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, Foam::keyType:ption) const
in file db/dictionary/dictionary.C at line 363.
FOAM exiting
I have kept the time step a bit large because I just want it to run at first, then I will make the time step finer. Also my courant number is shooting up to a lot.
I might have made some rookie mistakes, so kindly point them out to me.
Thank you!
uditrao04 is offline   Reply With Quote
Old   January 6, 2024, 15:18
NotOverUnderated's Avatar
ONESP-RO
NotOverUnderated is on a distinguished road
Inside the divSchemes dictionary in the file system/fvSchemes, add this line:
 div((nuEff*dev2(T(grad(U))))) Gauss linear;
Don't keep making the same mistakes. Try to make new mistakes.
NotOverUnderated is offline   Reply With Quote
Old   January 6, 2024, 15:47
Udit S Rao
I did it... but now its giving me a new error...
Create time
PISO: Operating solver in PISO mode
Reading field p
Reading field U
Starting time loop
Time = 0.5
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 4.5122e-06, No Iterations 5
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 1.41181e-06, No Iterations 5
smoothSolver: Solving for Uz, Initial residual = 0.000661307, Final residual = 7.04702e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0438961, No Iterations 141
DICPCG: Solving for p, Initial residual = 0.00681152, Final residual = 0.000245953, No Iterations 14
DICPCG: Solving for p, Initial residual = 0.000419764, Final residual = 1.64264e-05, No Iterations 144
time step continuity errors : sum local = 0.0404384, global = -0.000684349, cumulative = -0.000684349
DICPCG: Solving for p, Initial residual = 0.00646432, Final residual = 0.000214823, No Iterations 144
DICPCG: Solving for p, Initial residual = 0.00591995, Final residual = 0.000231605, No Iterations 14
DICPCG: Solving for p, Initial residual = 0.000404036, Final residual = 9.95925e-07, No Iterations 161
time step continuity errors : sum local = 0.00128751, global = 2.78271e-06, cumulative = -0.000681566
ExecutionTime = 0.25 s ClockTime = 0 s
Time = 1
Courant Number mean: 1015.83 max: 3220.46
[stack trace]
#1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#2 ? in /lib/x86_64-linux-gnu/libc.so.6
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#6 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
#7 Foam::fvMesh::solve(Foam::fvMatrix<Foam::Vector<do uble> >&, Foam::dictionary const&) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
#8 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/pisoFoam
#9 ? in /lib/x86_64-linux-gnu/libc.so.6
#10 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#11 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/pisoFoam
Floating point exception
The courant number is 1k....
error, pimplefoam, pisofoam
[RapidCFD] Discussion thread on how to install and use RapidCFD newoscar OpenFOAM Community Contributions 84 September 2, 2022 01:04
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 15:11
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
