Wall BC varying with tube radius
Like Tree1Likes
  • 1 Post By babakflame
Old   August 26, 2016, 04:49
Default Wall BC varying with tube radius
Giannokostas Konstantinos
k.giannoko is on a distinguished road
Hello Everyone,
If i have a pipe flow and I want to impose a slip condition at the wall varying with local tube radius, cause the tube is not straight but it's radius is different from point to point. How can I insert R in this expression :
Wall
type codedFixedValue;
value uniform (0 0 0);
redirectType rampedFixedValue;
code
vector (0, 0 , f(R)*DUz/Dy);
Thank you very much
k.giannoko is offline   Reply With Quote
Old   October 2, 2016, 13:50
Bobby
babakflame is on a distinguished road
Hey Giannokostas
Look at these two samples. Hope you find the idea
Before defining your vector, you need to define your function correctly.
 inlet     {
         redirectType    velocitySquareInlet;
             code         #{
             const fvPatch& boundaryPatch = patch();
              const vectorField& Cf = boundaryPatch.Cf();
               vectorField& field = *this;
              scalar min = 0.501;
               scalar max = 0.751;
           forAll(Cf, faceI)             {
                if (
                     (Cf[faceI].z() > min) &&
                    (Cf[faceI].z() < max) &&
                     (Cf[faceI].y() > min) &&
                    (Cf[faceI].y() < max)
                    field[faceI] = vector(0.1, 0, 0);
right
    value uniform 0;
    code
        (*this)==scalar(1.1*log(1.0));
//      (*this)==vector(0.5*sin(3.141592)*this->db().time().value())/2,0,0);
You can roughly do anything with codedFixedValue boundary Type.
Hope this helps.
babakflame is offline   Reply With Quote
Old   October 6, 2016, 03:52
Sachin
smodh is on a distinguished road
I am using codedFixedValue bc for implementing ΔV=0 ;where V=x2+y2+z2
my boundarycondition at 0/phi is:
inlet
value uniform 0;
code
scalarField& field = *this;
forAll(Cf, faceI)
(Cf[faceI].x()=0) &&
(Cf[faceI].y()=0) &&
(Cf[faceI].z()=0)
field[faceI] = ((Cf[faceI].x()*Cf[faceI].x())
+(Cf[faceI].y()*Cf[faceI].y())
+(Cf[faceI].z()*Cf[faceI].z()));
But in terminal I have error in BC
does anyone have idea where I am wrong?
thanks
smodh is offline   Reply With Quote
Old   October 6, 2016, 16:34
Bobby
Hey Sachin
Can u post the error and describing your boundary a little more? Is it a scalar or vector??
You are trying to define a gradient. Isn't gradient a vector?
Old   October 7, 2016, 03:43
Sachin
Good morning Bobi,
I solved problem. actually it is a scalar and the solution is
FoamFile
version 2.0;
format ascii;
class volScalarField;
object phi;
dimensions [1 2 -3 0 0 -1 0];
internalField uniform 0;
boundaryField
inlet
value uniform 0;
code
const vectorField& Cf[/B] = boundaryPatch.Cf();
forAll(Cf, faceI)
I don't under one thing in the code is, my class is scalar.
but in the code beginning, I have to write "const vectorField& CF"
why? My field is scalar.
now code is work perfectly....but still dont understand this function meaning.
Old   October 7, 2016, 10:36
Bobby
Hey Sachin
Good thing that u posted the final code for others.
It would be even nicer if u use the link for code so as your posted code becomes distinguishable from other lines.
cf() member function returns the location of the face center as a vector. So, when u want to use it to as a member function for an object (boundaryPatch) of class fvPatch, the result is a vectorField.
I tried to describe it clearly. Hope this helped you.
smodh likes this.
Old   October 14, 2016, 06:09
Default Navier Slip condition
Hello everyone ,
Thanks for your replies i found them very useful. But still wonder , how can I insert a velocity component derivative (i.e. dUz/dy) to impose a Navier-Slip condition at the wall using the codeFixed utility..
Thank you
K.G
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
U Tube Heat transfer- unable to get Nusselt No on wall Gowrav FLUENT 0 March 20, 2013 12:51
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
