Profile Initial Contidion
Like Tree2Likes
  • 1 Post By Dipsomaniac
  • 1 Post By FlyBob91
Old   October 21, 2016, 05:39
Exclamation Profile Initial Contidion
FlyBob91's Avatar
FlyBob91 is on a distinguished road
for my study i have to set the velocity and pressure profiles at the outlet of a channel as initial conditions at the inlet of another channel. The two channel have the same dimensios and number cells at the inlet and outlet.
So i have two problem:
1- how can i extract the outlet velocity profile? I tried to use post-processing tool like "probes" or "internalCloud" or "boundaryCloud" but i'm not able to set them to extract the profile at the outlet, because they are set to extract the velocity starting from point.
2- how can i set the velocity profile as initial condition at the inlet of the second channel?
Thanks for help
FlyBob91 is offline   Reply With Quote
Old   October 25, 2016, 04:51
Brian Willis
Dipsomaniac is on a distinguished road
Hello
Have a look at swak4Foam and the groovyBC boundary condition tool. It allows one to use an arbitrary expression to be used to set the boundary conditions. Else it is also possible to read in a data file as well.
Regards,
Brian
Dipsomaniac is offline   Reply With Quote
Old   October 25, 2016, 19:18
FlyBob91's Avatar
Hello Brian,
thank you for the suggestion about groovyBC boundary condition; it will be useful. Unfortunately, i cannot extract the outlet profile yet.
Best Regards,
Roberto
Old   October 26, 2016, 01:17
Brian Willis
Hi Roberto
To extract the velocity profile, have you tried using Paraview to extract it at the outlet? You can view just your outlet patch (or a slice near it) and view the velocities then.
Regards,
Brian
FlyBob91 likes this.
Old   October 26, 2016, 05:36
FlyBob91's Avatar
Hi Brian,
thank you, for the second time, for your suggestion. I was so focused in using the OpenFoam utility that i haven't taken into account ParaView.
As you told me i selected only the ouput region for the mesh and then i saved the data in CSV format.
Best Best Regards,
Roberto
Dipsomaniac likes this.
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
Simulation seems to converge but crashes suddenly xxxx OpenFOAM 16 September 12, 2014 08:07
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
