March 28, 2017, 07:25 |
sprayFOAM sizeDistribution type general
Henning
Hello everyone,
I wasn't able to find information about the parameters entered in general in sizeDistribution. I don't know what exactly the inputs are. I was able to find some examples of generalDistribution(see below), however these don't enlighten me. I already know that the first column is diameter and the second column is a probability which does not need to be normalized. However, which probability to enter here I don't know. Can anyone help? Might the input be Code:
xi q3(xi) Code:
xi q3(xi)*∆xi q3(xi) here is of dimension 1/µm Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object particleProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solution { active true; coupled true; transient yes; cellValueSourceCorrection off; interpolationSchemes { rho.air cell; U.air cellPoint; mu.air cell; } integrationSchemes { U Euler; } sourceTerms { schemes { U semiImplicit 1; } } } constantProperties { parcelTypeId 1; rhoMin 1e-15; minParcelMass 1e-15; rho0 2526; youngsModulus 1e8; poissonsRatio 0.35; constantVolume false; alphaMax 0.99; } subModels { particleForces { ErgunWenYuDrag { alphac alpha.air; } gravity; } injectionModels { model1 { type patchInjection; massTotal 0; parcelBasisType fixed; nParticle 1; SOI 0; parcelsPerSecond 100; duration 1; patchName INLET; U0 (0 30 0); flowRateProfile constant 1; sizeDistribution { type general; generalDistribution { distribution ( (05e-05 5.19202) (10e-05 33.91157) (15e-05 24.78618) (20e-05 14.25689) (25e-05 8.68968) (30e-05 5.07100) (35e-05 3.130547) (40e-05 1.795223) (45e-05 1.1497498) (50e-05 0.6737130) (55e-05 0.5002420) (60e-05 0.2944973) (65e-05 0.1855736) (70e-05 0.10085525) (75e-05 0.1129578828) (80e-05 0.0726157818) ); } } } } dispersionModel none; patchInteractionModel localInteraction; localInteractionCoeffs { patches ( INLET { type rebound; e 0.97; mu 0.09; } OUTLET { type rebound; e 0.97; mu 0.09; } AUSSLASSROHR { type rebound; e 0.97; mu 0.09; } AUSSLASSGLOCKE { type rebound; e 0.97; mu 0.09; } EINLASSROHR { type rebound; e 0.97; mu 0.09; } MESSKAMMER { type rebound; e 0.97; mu 0.09; } DUESE_INNEN { type rebound; e 0.97; mu 0.09; } DUESE_STIRNFLAECHE { type rebound; e 0.97; mu 0.09; } DUESE_AUSSEN { type rebound; e 0.97; mu 0.09; } ); } StandardWallInteractionCoeffs { type rebound; e 0.97; mu 0.09; } heatTransferModel none; surfaceFilmModel none; collisionModel pairCollision; pairCollisionCoeffs { maxInteractionDistance 0.0025; writeReferredParticleCloud no; pairModel pairSpringSliderDashpot; pairSpringSliderDashpotCoeffs { useEquivalentSize no; alpha 0.02; b 1.5; mu 0.10; cohesionEnergyDensity 0; collisionResolutionSteps 12; }; wallModel wallSpringSliderDashpot; wallSpringSliderDashpotCoeffs { useEquivalentSize no; collisionResolutionSteps 12; youngsModulus 1e8; poissonsRatio 0.23; alpha 0.01; b 1.5; mu 0.09; cohesionEnergyDensity 0; }; UName U.air; } stochasticCollisionModel none; radiation off; } cloudFunctions {} // ************************************************************************* // Last edited by Trollstoi; March 29, 2017 at 05:20. |
March 29, 2017, 11:10 |
Henning
As I understand the final formula of the equation in general.c results in:
y_n+1 - y_n = 0,5 * (x_n+1 - x_n) * (q_3(x_n+1) + q_3(x_n)) the dimension of q3 is also of no importance in this case because all "sieves" are equal in size and therefore q3 and q3*∆x will yield the same result. |
[Other] simulation of closing the gate using moving mesh | simin_ds | OpenFOAM Meshing & Mesh Conversion | 8 | April 12, 2019 05:49 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
Strange high velocity in centrifugal pump simulation | huangxianbei | OpenFOAM Running, Solving & CFD | 26 | August 15, 2014 02:27 |
SimpleFoam - instable simulation | Specialist | OpenFOAM Running, Solving & CFD | 17 | August 12, 2014 04:52 |
[swak4Foam] Air Conditioned room groovyBC | Sebaj | OpenFOAM Community Contributions | 7 | October 31, 2012 14:16 |
