Using AMI without multi-region meshing
Old   May 28, 2017, 18:57
Default Using AMI without multi-region meshing
me3840 is on a distinguished road
Hello folks,
I would like to use the AMI on a different mesh setup than all of the tutorials. For complex geometries I find that the multi-region meshing feature of snappyHexMesh is really unreliable. As an alternative, I mesh each region independently and combine them later.
The trouble here is, from what I can tell, the AMI setup using createBaffles can only be done with a conformal interface. The tutorials will split the baffles into two sides using mergeOrSplitBaffles after creating them. But for me, they are already split - but the createBaffles dictionary doesn't allow me to specify two faceZones, one for each side of the interface.
So how would I get around this? Anyone done something like this before?
me3840 is offline   Reply With Quote
Old   June 1, 2017, 01:43
Solution is easy, just make two AMIs and tell them they're each other's neighbor. Assign the slaves a dummy patch and it works.
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 07:55
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
Suggestions for a multi region conjugate heat transfer problem maddalena OpenFOAM 14 September 4, 2013 18:03
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
