Is this case more suited to multiphase solvers?
Old   July 6, 2017, 14:35
Default Is this case more suited to multiphase solvers?
Max
Speno93 is on a distinguished road
Hi there,
I am trying to set up a simulation where I am examining the behaviour of a evaporating volatile chemical. However in simplifying the simulation I am assuming that the chemical exists at the floor boundary as a saturated vapour, rather than going through a liquid phase first.
I had originally planned to use the rhoSimpleFoam solver (with some modifications from previous theory work) as my solver. But having a longer think about it, I started to consider that since I am examining the dispersal of the volatile chemical through air, as well as examing how airflow affects the movement of the chemical, that maybe I would be more suited to modifying a multiphase solver, such as compressibleInterFoam for the gases.
So I guess my question is, is this thinking logical? Is there anything that I am not considering here?
EDIT: Or just after doing a little more research, would twoPhaseEulerFoam be the ideal multiphase solver?
Speno93 is offline   Reply With Quote
Old   July 7, 2017, 04:59
BlnPhoenix is on a distinguished road
I would say twoPhaseEulerFoam is better if not the correct choice here. Two gases have no macroscopical interface they share, so interFoam is not doing it i suppose.
You could also concider reactingTwoPhaseEulerFoam, which can allow you later to include some form of mass transfer, evaporation, chemical reaction etc. if needed.
BlnPhoenix is offline   Reply With Quote
Old   July 7, 2017, 13:31
Max
yeah that does sound about right, however I am not sure as technically I do not have two phases, as its just a volatile gas dispersing in air. So would a different model,perhaps treating the volatile liquid as a passive scalar.
Old   July 10, 2017, 06:57
Speno, yes. I think if properties are similar i think it is fair to simulate the dispersion with a passive scalar. In that case you would not need a multiphase solver.
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 06:06
CFD Post - How to check for case in an expression pilakin ANSYS 0 September 26, 2014 05:44
How to Initialise my LES case using my RANS case is there any utility for it ? Alhasan OpenFOAM Running, Solving & CFD 2 May 10, 2014 01:14
Multiphase and Non Newtonian fluid wanna88 FLUENT 0 May 27, 2013 01:09
Multiphase solvers Theory titio OpenFOAM Running, Solving & CFD 1 November 20, 2009 18:23
