rakesh
Rep Power: 14 ![]() |
Does anybody know how to use SurfaceToCell utility for an irregularly shaped surface. The main problem comes in the definition of outside points. I have an .stl file with tree height information. How to map this using surfacetocell utility. The clarity the syntax of the surface to cell is posted below. Please help!!! actions ( { name porosity1; type cellSet; action new; source surfaceToCell; sourceInfo { file "constant/triSurface/tree.stl"; useSurfaceOrientation false; outsidePoints ((1000 1200 1000)); // definition of outside ! How to specify this ?? includeCut true; // cells cut by surface includeInside true; // cells not on outside of surf includeOutside false; // cells on outside of surf nearDistance -1; // cells with centre near surf // (set to -1 if not used) curvature -1; // cells within nearDistance // and near surf curvature // (set to -100 if not used) } } ); |
Display Modes | |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Noise postprocessing utility setup | RFlamm | OpenFOAM Post-Processing | 5 | July 30, 2018 10:06 |
wallHeatFlux Calculation wrt utility version | ahmet | OpenFOAM Post-Processing | 1 | December 18, 2016 19:45 |
[mesh manipulation] mirrorMesh utility preserving regions | zfaraday | OpenFOAM Meshing & Mesh Conversion | 1 | November 7, 2016 21:51 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 16:47 |
