Flipping the direction of FanPressure BC
Old   December 8, 2017, 05:02
Default Flipping the direction of FanPressure BC
Matt Houchin
HouchinM is on a distinguished road
I am trying to apply a fanPressure BC to an internal fan casing, using createBaffles.
I have created the baffles and applied the fanPressure boundary condition to the p field.
Everything is working correctly, except that the inlet flow is reversed, such that it behaves as an outlet (see attached image). I have tried changing the direction and the sign of the value in the fanPressure BC, but with no luck.
Has anyone been able to get the fanPressure direction to change?
p:
boundaryField
    atmosphereBoundary
        type            fixedValue;
        value           uniform 0;
    ductWork
        type            zeroGradient;
    fanCasing
        type            zeroGradient;
    plenumWall
        type            zeroGradient;
    systemBoundary
        type            fixedValue;
        value           uniform 0;
    baffle_master
        type            fanPressure;
		fileName        "fanCurve";
		outOfBounds     clamp;
		direction       out;              // in | out
		p0              uniform 0;
		value           uniform 50;
		gamma			0;
    baffle_slave
        type            fanPressure;
		outOfBounds     clamp;
		direction       in;              // in | out
		p0              uniform 0;
		value           uniform -50;
		gamma			0;
createBafflesDict:
internalFacesOnly true;
baffles
// NOTE: cyclicAMI patches MUST BE defined PRIOR to their associted
// blockage patches
baffle
//- Use predefined faceZone to select faces and orientation.
type faceZone;
zoneName fanSource;
patchPairs
type patch;
TopoSetDict:
actions
name fanSource;
type faceZoneSet;
action new;
source searchableSurfaceToFaceZone;
sourceInfo
surface triSurfaceMesh;
name baffle.stl;
name fanSourceSlave;
type cellSet;
action new;
source faceZoneToCell;
sourceInfo
name fanSource;
option slave;
HouchinM is offline   Reply With Quote
Old   December 8, 2017, 05:49
Default Solved
Matt Houchin
For anyone wondering, I had my pressure boundary conditions entered in wrong.
Here is the correct boundary conditions to use:
p:
boundaryField
atmosphereBoundary
type fixedValue;
value uniform 101325;
ductWork
type zeroGradient;
fanCasing
type zeroGradient;
plenumWall
type zeroGradient;
systemBoundary
type fixedValue;
value uniform 101375;
baffle_master
type fanPressure;
fileName "fanCurveOut";
outOfBounds clamp;
p0 uniform 101325;
gamma 0;
baffle_slave
type fanPressure;
fileName "fanCurveIn";
outOfBounds clamp;
p0 uniform 101375;
gamma 0;
FanPressure BC direction reversal HouchinM OpenFOAM Running, Solving & CFD 1 December 11, 2017 08:42
fanPressure BC for a suction fan, how it works? student666 OpenFOAM Pre-Processing 1 January 18, 2017 11:47
ERROR: Flow direction on the boundaries must not be tangential to the boundary. turbomax CFX 2 August 6, 2015 11:05
fanPressure BC pingat OpenFOAM Running, Solving & CFD 0 November 8, 2013 02:52
Changing inflow velocity direction deteriorates lift and drag ziggo FLUENT 3 July 24, 2013 08:39
