Support needed regarding Boundary Conditions.
Old   January 17, 2018, 07:08
Default Support needed regarding Boundary Conditions.
Georg
Schurl is on a distinguished road
Hi All,
I am Really struggling to choose the right BC.
I have to state, that i last worked with CFD 15 Years ago at the university using StarCD and icem.
I can handle in principle Navier-Stokes EQ but i am not able to derive alle the turbulence models behind openFOAM especially using sonicFoam.
I remember with StarCD i just had to define surfaces and apply BC like pressure or velocity at inlet, ambient pressure at outlets, walls wheter as no slip or symmetry.
Now have to define the BC in approx. 7 files where i honestly copy and paste the BC from the tutorials with a lot of except p and u.
As i turned now from given inlet velocity to high pressure at the inlet it does not work anymore and i am lost in all those files k, epsilon etc.
Does someone has an overview of usual BC for a specific solver like sonicFoam? The should be always same or?
Thanks in advance
Georg
Schurl is offline   Reply With Quote
Old   January 17, 2018, 17:06
Tosbaga's Avatar
Tosbaga
Tosbaga is on a distinguished road
Hello this link can be usefull to you
https://www.openfoam.com/documentati...conditions.php
Regards
Tosbaga is offline   Reply With Quote
Old   January 19, 2018, 15:56
Georg
thanks, but I knew this link already.
My problem is, what i should use for sonicFoam for just a simple channel for example: Inlet-outlet-walls, where at the inlet is 1.01 bar, at the outlet 1bar.
I have to define BC for
- T
- U
- P
- alphat
- epsilon
- k
- nut
Here I am lost. I use the ones from other examples, but the results are unfortunatel unplausible.
Kind regards
George
CGNS Boundary conditions using SU2 denzell SU2 3 July 9, 2018 05:58
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 17:19
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
