accessing value of contact angle
Old   February 27, 2018, 14:18
Default accessing value of contact angle
Amir
KillerBee is on a distinguished road
Hey Guys,
with hoping that my problem fits into this category, was wondering if anyone could help with accessing and changing the value of contact angle for a certain patchID?
in other words to break it down, I wanna change the value of contact angle within the main code block (not where the alpha property is defined) to another value for a certain patch (let's call it wall) within a certain region (like a box) of the mesh (not everywhere)?
since the BC I'm dealing with is a alphaContactAngleFvPatchScalarField, was wondering if I can use setFields to define a region (box in this case) and apply this change (if so please specify how I can do this), and if not any other suggestion?
any help is highly appreciated!
KillerBee is offline   Reply With Quote
Dynamic contact angle calculation in multiphaseInterFoam rajeshchem OpenFOAM 3 December 23, 2022 14:00
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 02:39
inaccurate contact angle capturing in high shear/viscousity flow chery1986 OpenFOAM Running, Solving & CFD 0 October 23, 2015 00:14
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
