July 24, 2018, 16:18 |
Convective Heat transfer in laplacianFoam
Fridrik Magnusson
Rep Power: 8 |
Hallo everyone
i'm simulating some fins in laplacianfoam, and would like to make a convective boundary condition, but i can't seem to find the right one to impose. Does anybody have any experience with such a BC - and can push me in the right direction ? - Fridrik Magnusson |
July 25, 2018, 04:49 |
Further investigation
Fridrik Magnusson
Rep Power: 8 |
Tobi [1] suggest to use "laserConvection"[2] but i dont really know what all the fields mean, if you guys has any ideas please fill me in
myPatch { type laserConvection; //Type of BC value uniform 300; //Unknown (maybe initial condition) HTCheating 150; //Heat transfer cofficient at heating HTCquenching 150; //Heat transfer cofficient at cooling TfH 300; //Referance temperature at heating TfQ 300; //Referance temperature at cooling heatingTime 10; //Unknown (maybe the start time of heating/cooling) kValue 0; //Unknown (maybe constant conduction) }; [1] Mixed BC - heat transfer - laplacianFoam [2] https://bitbucket.org/shor-ty/laserconvectionbc |
July 25, 2018, 08:12 |
anonymous
Rep Power: 14 |
Hi!
Have you seen the convectiveHeatTransfer... BC? I think this is for flat plate, but if you know your equation for the nusselt number in your case (if not a flat plate), you can simply create your BC based on it (Just rewrite the equation and compile it). https://cpp.openfoam.org/v6/classFoa...d.html#details BTW the 1st unknown ("value") is the initial condition. I don't know the others, but you can check them in the code. (the beauty of OF.) |
July 25, 2018, 09:48 |
Fridrik Magnusson
Rep Power: 8 |
Hi Simrego, i would like to decide the htc, then this might work. It seems like Nu, Re and Pr are calculated from a vectorfield, but im not that good at reading source files. Where does convectiveHeatTransfer get the Nu, Re and Pr from ?
July 25, 2018, 15:55 |
anonymous
Rep Power: 14 |
Re and Pr are calculated from the velocity, mat props, etc.
Pr, Re: line 136, 143. https://cpp.openfoam.org/v6/convecti...8C_source.html Nu is the ration between convective and conductive heat transfer: Nu = h * L / k, which can be written as: h = Nu * k / L You use this equation in line 145-152. Where the Nu is some fancy function depending on Pr, and Re, and the end of the equation you can find that multiplication with kappa, and division with L. In the code you can find it for flat plate (i think, i'm not sure, you should check it). You can find Nu for many applications on the internet. So if you have something else (not flat plate), you should rewrite the code between line 145-152. |
July 25, 2018, 16:03 |
anonymous
Rep Power: 14 |
Or i don't know what is your goal exactly, but maybe externalWallHeatFlux could be good for you:
https://cpp.openfoam.org/v6/classFoa...d.html#details This is a boundary condition which can operate in three modes. Details in the link. |
July 25, 2018, 16:28 |
Fixed h
Fridrik Magnusson
Rep Power: 8 |
dud Last edited by Fridrik; July 25, 2018 at 16:33. Reason: Double post |
July 25, 2018, 16:29 |
Fixed h
Fridrik Magnusson
Rep Power: 8 |
Hi again Simrego, thanks for your suggestions.
I think it is possible to make a rewrite the "convectiveHeatTransfer" to get the "htc" from the ./0/T BC something from: Code:
{ label celli = patch().faceCells()[facei]; scalar Re = rhow[facei]*mag(Uc[celli] - Uw[facei])*L_/muw[facei]; if (Re < 5.0E+05) { htc[facei] = 0.664*sqrt(Re)*cbrt(Pr[facei])*kappaw[facei]/L_; } else { htc[facei] = 0.037*pow(Re, 0.8)*cbrt(Pr[facei])*kappaw[facei]/L_; } } to Code:
{ label celli = patch().faceCells()[facei]; htc[facei] = Get constant from file; //psudocode } If i use the "externalWallHeatFlux" like this Code:
internalSurface { type externalWallHeatFluxTemperature; mode coefficient; Ta uniform 273; // fluid temperature h uniform 2000; //convective heat rate thicknessLayers (0.1 0.2 0.3 0.4); //unknown kappaLayers (1 2 3 4); // unknown kappaMethod fluidThermo; // unknown (Seems to be the cause for error) value uniform 300; // initial value } i get the following error: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-e05f780ebc87 Exec : laplacianFoam Date : Jul 25 2018 Time : 22:17:45 Host : "fridrik-VirtualBox" PID : 1624 I/O : uncollated Case : /home/fridrik/OpenFOAM/HeatTransfer/Bracket nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: No convergence criteria found Reading field T Reading transportProperties Reading diffusivity DT No finite volume options present Calculating temperature distribution Time = 0.005 --> FOAM FATAL ERROR: kappaMethod defined to employ fluidThermo method, but thermo package not available From function Foam::tmp<Foam::Field<double> > Foam::temperatureCoupledBase::kappa(const scalarField&) const in file turbulentFluidThermoModels/derivedFvPatchFields/temperatureCoupledBase/temperatureCoupledBase.C at line 171. FOAM exiting |
July 25, 2018, 16:52 |
#9 |
anonymous
Rep Power: 14 |
1. what do you mean under "link to another file"?
2. You use laplacianFoam, you have no thermo package there. Now I'm a bit lost, didn't noticed it cannot be used in laplacianFoam. The not so elegant but working solution can be if you use chtMultiRegion with only one region (maybe there are other solutions too) 3. I should did it much much earlier, but what is your problem description? What do you have, what do you want, etc. |
July 26, 2018, 13:52 |
#10 |
Fridrik Magnusson
Rep Power: 8 |
ill start from the back
3. I want to make a code which can generate the best cross sectional fin array, which must remain closed. By utilizing topology optimization. Since working with very limited computational power. The i think the best starting point is to just solve the steady state heat equation for a 2-D cross section. Where the boundary convective condition is based on empirical approximations [Nu(Re,Pr)]. Step one will be to solve a basic case, by applying the correct BC which is what we are discussing Step two will be to setup the topological stuff (which is really hard) 2. Ill look into using chtMultiRegion instead of laplacianFoam 1. i mean i want to reference to a constant maybe in transportProperties. I hope this makes sense |
boundary condition, convection, thermal analysis |
Thermal non-equilibrium porous media model with conjugate heat transfer | Hexahedron | FLUENT | 9 | February 22, 2023 02:55 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
(Convective Heat Transfer Coefficient) | idefix | STAR-CCM+ | 0 | July 27, 2016 05:18 |
Convective & conductive heat transfer | gimmetwofingers | OpenFOAM | 7 | January 31, 2012 09:36 |
