January 10, 2019, 09:11 |
Continuity between Inlet and Outlet
Bernhard
Rep Power: 7 |
i just want to generally ask if there is a possibility to apply a boundary condition for the outlet that is able to maintain continuity concerning a given inlet boundary condition? What I mean is, that I specified a certain velocity for the inlet and I want a boundary condition that automatically computes the corresponding velocity for the outlet, so that the mass flow is constant. Thanks in advance! |
January 10, 2019, 17:22 |
Rep Power: 14 |
January 23, 2019, 04:47 |
Bernhard
Rep Power: 7 |
Thank you very much Caelan!
February 26, 2019, 18:53 |
Mattia
Rep Power: 7 |
Thanks for the hint Caelan.
What about p field in this case? Should be set to zeroGrandient for all patches? Any particular advise? Bye |
February 28, 2019, 08:49 |
Rep Power: 14 |
My first guess is that this might work bc the incompressible solvers always set a reference pressure (usually zero) somewhere in the domain. I would try it to make sure.
Caelan |
February 28, 2019, 09:45 |
Bernhard
Rep Power: 7 |
I think so too, just use zeroGradient for the inlet and the outlet and it should work. I also did that.
Greets hebe03364 |
March 7, 2019, 21:20 |
Pressure BC
#7 | |
Rep Power: 10 |
I am not sure whether zeroGradient is a "physical" boundary condition. If I understood correctly, you want some kind of cyclic boundary condition that keeps continuity in an integral sense. Then, the pressure gradient should be somehow given by the flow conditions rather than imposed. I have not tried it, but fixedFluxPressure should calculate pressure gradient according to the velocity condition: https://github.com/OpenFOAM/OpenFOAM...hScalarField.H If this does not work you might want to run HTML Code:
simpleFoam -listScalarBCs |
January 13, 2020, 10:12 |
Rep Power: 6 |
Dear All,
Greetings. I was wondering if the matchedFlowRateOutletVelocity would avoid the problems of backflow at the outlet boundary. Also, I use twoLiquidMixingFoam multiphase solver, what would be a compatible phase boundary condition? Please let me know if I should provide more details for my simulation case. Thanks. |
Pressure Boundary Inlet and Outlet | AS_Aero | CFX | 5 | March 28, 2018 10:46 |
Outlet BC for pipe flow with oscillatory inlet | EmiS | FLUENT | 1 | August 14, 2015 13:59 |
pump outlet pressure higher than inlet pressure | jstan3 | FLUENT | 14 | February 13, 2014 23:44 |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
define BCs at inlet and outlet for natural ventilation simulation | jjz2013 | Main CFD Forum | 0 | January 29, 2013 15:50 |
