how to create tapered cylinder with topoSet
Old   February 19, 2019, 22:48
Default how to create tapered cylinder with topoSet
Honey
Honey is on a distinguished road
I am willing to create a tapered cylinder in middle of a box with using topoSetDict. I know that is not implemented in OpenFOAM and requires some modification into cylinderToCell.C code located at .../src/meshTools/sets/cellSources/cylinderToCell. Nevertheless, I tried to modify the main function written in cylinderToCell.C from:
void Foam::cylinderToCell::combine(topoSet& set, const bool add) const
const vector axis = p2_ - p1_;
const scalar rad2 = sqr(radius_);
const scalar magAxis2 = magSqr(axis);
const pointField& ctrs = mesh_.cellCentres();
forAll(ctrs, cellI)
vector d = ctrs[cellI] - p1_;
scalar magD = d & axis;
if ((magD > 0) && (magD < magAxis2))
scalar d2 = (d & d) - sqr(magD)/magAxis2;
if (d2 < rad2)
addOrDelete(set, cellI, add);
to:
void Foam::taperedCylinderToCell::combine(topoSet& set, const bool add) const
const scalar radBase2 = sqr(radiusBase_); //**modified
const scalar radTop2 = sqr(radiusTop_); //**added
forAll(ctrs, cellI)
if ((d2 < radBase2) && (d2 > radTop2)) //**modified
Obviously, it generated a hollow cylinder instead of a tapered cylinder I would highly appreciate if anyone here could help me to successfully modify this piece of code!
Thank you in advance
Honey is offline   Reply With Quote
taperedcylindertocell
[blockMesh] Creating a tapered cylinder tanveerfathima OpenFOAM Meshing & Mesh Conversion 1 December 4, 2018 07:22
Flow through small cylinder recirculated inside larger cylinder. Keesie FLUENT 1 July 28, 2016 05:30
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 07:01
[snappyHexMesh] Create cylinder around snappyHexMesh for MRF/rotating linnemann OpenFOAM Meshing & Mesh Conversion 6 October 20, 2014 00:19
[snappyHexMesh] How to create an open cylinder using FreeCAD meng9019 OpenFOAM Meshing & Mesh Conversion 3 March 14, 2014 09:24
