Maciej
Rep Power: 8 ![]() |
Hello everyone,
i want to ask you about some help with my problem. The thing is that i calculated timestep, i've put it in controlDict and everything is fine until my simulation get to about 200 - 300 iteration. Before this, maximum Courant number is about 0,001... , but after about 200 - 300 iterations it immidiately (after 2 iterations raised to 1,64e+47) Could you please tell me where is the problem? Is it still too high timestep? |
Peter Hess
Rep Power: 18 ![]() |
Hello MagicCFD
![]() set: adjustTimeStep true; to false and see what happends... Like that openFoam is executing the deltaT you define in the controlDict without overwriting this... And it is helpful to limit courant to 1 by using: maxCo 1; in controlDict. ... anyway, it is a good idea to start with: adjustTimeStep false; run some iterations and then turn it to true... Regards Peter Last edited by peterhess; March 27, 2019 at 11:31. |
Display Modes | |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
parallel run OpenFoam | Srinath Reddy | OpenFOAM Running, Solving & CFD | 13 | February 27, 2019 09:15 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
