Use 2D-profile as Input boundary
Old   March 13, 2019, 13:30
Default Use 2D-profile as Input boundary
Sandro
huttata is on a distinguished road
i want to use an 2D-Veocity profile as boundary for an Simulation. when i try to run it, the fatal Error:
--> FOAM FATAL ERROR:
out-of-order value: 0.00456486 at index 2
From function void Foam::Function1Types::TableBase<Type>::check() const [with Type = Foam::Vector<double>]
in file lnInclude/TableBase.C at line 208.
FOAM exiting
appears.
This is how i implemented the csv file in the 0 folder.
boundaryField
Inlet
type fixedProfile;
profile csvFile;
direction (0 1 1);
origin (0 -0.15 0.025);
profileCoeffs
nHeaderLine 0;
refColumn 0;
componentColumns (2 3 4);
separator ",";
mergeSeparators no;
file "inlet/inlet_U.csv";
outOfBounds clamp;
interpolationScheme linear;
The csv file has the y- and z-coordinates in column 0 and 1, and the 3 Velocity components in column 2 3 and 4.
Does anyone know where my mistake is? I didn't find anything on the internet.
Thanks
huttata is offline   Reply With Quote
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
