Couldn't get 2 regions while using sliding MRF |
July 6, 2019, 03:09 |
Milan
Rep Power: 9 |
Dear all,
I have been modifying the sliding_MRF_meshes case file of wolfDynamics to fit my case. During the process, I could not get 2 regions. Also, when I check it through splitMeshRegions -detectOnly | tee log.splitMeshRegions_2 I got only single region named cell_inner_volume. I could not get any AMI1 and AMI2 patch weights on checking through moveDynamicMesh -checkAMI -noFunctionObjects Both the case file and reference file has been shared through the link https://drive.google.com/drive/folde...5C?usp=sharing The simulation gif of sliding_MRF_meshes: Sliding grids – Unsteady solver MRF – Steady solver What could be the possible error in my case setup? If you could help it would be great. Please feel free to ask if you have any doubts. Thank you for your time and consideration. Sincerely, Milan |
ami patches, amicyclic, mrf rotor atmosphere, mrf., region status issues |
Settings for sliding mesh or MRF in Ansys FLUENT | sgysin | FLUENT | 0 | September 26, 2018 14:39 |
Shifting from MRF to SLiding mesh | er_ijaz | ANSYS | 0 | May 13, 2016 00:25 |
Moving Wall, MRF or Sliding Mesh for modelling rotating rim and tyre? | Field85 | FLUENT | 3 | March 18, 2016 10:09 |
Sliding mesh vs MRF in axial turbine simulation | Vito | FLUENT | 3 | December 21, 2011 04:57 |
MRF solution data for Sliding mesh simulation | Tantular Nurtono | FLUENT | 4 | March 20, 2006 21:18 |
