How to calculate molWeight for reactants and products in XiFoam?? |
December 2, 2019, 01:16 |
Sangmin Kim
Rep Power: 6 |
Hi OpenFOAMers!!
I am looking for the way to set the thermophysiclProperties for wet hydrogen premixed combustion. (H2 + Air + Steam) If I set the mixture type to homogeneousMixture, only can set the category for reactants and products. (not fuel - oxidant - burntProducts) As like tutorials/combustion/XiFoam/RAS/moriyoshiHomogeneous/constant/thermophysiclProperties For this, how to calculate molWeight for reactants and products for this mixture (10% H2 + 65% Air + 25% Steam)?? (I`m very sorry about not attach example thermophysiclProperties file.) |
November 27, 2021, 15:50 |
How to create a thermoType for premixed gas mixtures in XiFoam?
#2 | |
Uğur
Rep Power: 4 |
I am also suffering from a similar situation. I want to burn 90% methane - 10% hydrogen gas mixture as pre-mixed by enriching oxygen at different rates. Equivalence ratio 0,7 and Su is constant The reactants consist of 90% methane - 10% hydrogen, air and additional oxygen gas. How can I determine lower, upper and common temperature values and high temperature coeff and low temperature coeff values for reactants and products? I couldn't figure out how to create thermo properties in the constant/thermophysicalProperties directory in XiFoam solver. FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heheuPsiThermo; mixture homogeneousMixture; transport sutherland; thermo janaf; equationOfState perfectGas; specie specie; energy absoluteEnthalpy; } stoichiometricAirFuelMassRatio stoichiometricAirFuelMassRatio [0 0 0 0 0 0 0] ???????; reactants { specie { nMoles ?????; molWeight ?????; } thermodynamics { Tlow ???; Thigh ????; Tcommon ????; highCpCoeffs ( ????????????? ); lowCpCoeffs ( ???????????? ); } transport { As 1.67212e-06; Ts 170.672; } } products { specie { nMoles 1; molWeight ?????; } thermodynamics { Tlow ???; Thigh ????; Tcommon ????; highCpCoeffs ( ????????????? ); lowCpCoeffs ( ????????????? ); } transport { As 1.67212e-06; Ts 170.672; } } // |
March 6, 2022, 20:25 |
#3 | |
Dilshan Casseer
Rep Power: 8 |
March 6, 2022, 20:35 |
Dilshan Casseer
Rep Power: 8 |
For anyone who are still looking for an answer, How you calculate the molWeight is,
molWeight = ΣWiXi, where Wi is molar weight of individual species and Xi is mol fraction of that species. To find the janaf coefficients, you can use databases from GRI MEch or Burcats. These databases have the 14 coefficients listed. (They will have 15 coefficients, disregard the last one of third row). They are in 3 rows, don't be afraid, its just one row after the other. The 1st 7 are highCp and the next 7 are lowCp. Find the coefficients for individual species from these files and use a similar calculation to above to find the JANAF coefficients for a mixture. The Thigh qnd Tlow a should be at the begining of each element in these files (ie 200.000 6000.000). You can also use adiabaticFlame T to calculate the janaf coefficients. Type cd $FOAM_UTILITIES/thermophysical/adiabaticFlameT then adiabaticFlameT controlDict you will get a file with data for each stoicheometric ratio calcualted. By default, controlDict has selected values for H2. the lines $H2; // $CH4; // $PROPANE; specieis the fuel in this. |
Temperature calculation from total enthalpy in OpenFOAM (XiFOAM) | sharifi | OpenFOAM Running, Solving & CFD | 1 | October 8, 2020 09:16 |
XiFoam floating point error..mut error? | achinta | OpenFOAM | 8 | July 31, 2012 04:48 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
