October 25, 2019, 08:42 |
Pressure drop equation as an outlet BC
Frédéric MR
Rep Power: 6 |
Hello OF users,
Considering you are simulating a fluid flow through a manifold (whose goal is to feed multiple pipes with the same pressure drop characteristics) and you want to evaluate how flow is distributed in the different pipes without modelling pipes (in order to simplify, we consider a single outlet surface from which pipes are starting) . The question is : - is there a BC able to implement a pressure drop equation in the outlet surface so that the fluid flow would take into account the downstream characteristics? If not possible I thought to make 2 different fluid parts, with the pipe part simulated as a porous region. And in this case, do I have to make a multi region simulation? Thank you a lot for the time you spend for me. Fred |
November 4, 2019, 04:17 |
Nima Samkhaniani
Rep Power: 24 |
if you have an equation for pressure drop at the outlate, you can implement it with swak4Foam
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
December 3, 2019, 08:52 |
Frédéric MR
Rep Power: 6 |
Thank you for the answer Nimasam. I'm going to take a look at this.
Discrepancy between the measurements (pressure drop; VOF) | blackemperor | FLUENT | 2 | March 6, 2016 03:40 |
Outlet boundary condition for pressure correction and navier stokes equation | Jan Smedseng | Main CFD Forum | 9 | January 28, 2016 03:12 |
pressure drop calcs 0MPa outlet vs 250kPa | Steffen595 | FLUENT | 0 | March 26, 2014 16:08 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
