Transonic reactingFoam
Like Tree1Likes
  • 1 Post By clapointe
Old   January 14, 2020, 11:43
Default Transonic reactingFoam
Tommaso M.
TommyM is on a distinguished road
Hi All,
I am trying to switch on the "transonic" option in reactingFoam. It should be exist in this solver since I have found it in the solver implementation.
Anyway, when I try to run the solver, it completely ignore the "div(phiv, p)" term in the fvSchemes, so I don't know if I am using it correctly.
Does anyone know something about it?
Thanks in advance.
Tommy
TommyM is offline   Reply With Quote
Old   January 14, 2020, 17:06
clapointe is on a distinguished road
I am only aware of its usage in the energy equation (below) that is used if internalEnergy is chosen. It is not used in the pressure equation (but phid is).
          he.name() == "e"
          ? fvc::div
                fvc::absolute(phi/fvc::interpolate(rho), U),
                p,
                "div(phiv,p)"
          : -dpdt
Caelan
TommyM likes this.
clapointe is offline   Reply With Quote
Old   January 15, 2020, 05:28
Tommaso M.
Hi Caelan,
Thanks for your reply.
I have chosen sensibleEnthalpy so the "phiv" term does not come into my equations, as you said.
I am trying to use reactingFoam to simulate chemical reactions in a supersonic flow (Ma~1.8).
Anyway, I should switch my energy equation to "internalEnergy" in order to do that (as far as I know, "e" equation is preferable to "h" equation in supersonic flows).
Can you give me your opinion about this, please?
Tommy
P.S.: I know that the PIMPLE-based solvers are not the optimal choice for this kind of problems, but at the moment I have not been able to implement reactions in rhoCentralFoam.
Old   January 15, 2020, 12:06
I do not have much experience using reactingFoam for (tran)sonic problems, so I will refrain from commenting on e vs h thermo. Perhaps someone else could be more help (or you could test yourself). For density-based reacting solvers there are various ones floating around -- e.g. hyFoam, various threads about reacting rhoCentralFoam, etc.
Caelan
Old   January 15, 2020, 12:28
Tommaso M.
Yes, I already read these threads, in particular reacting rhoCentral, but the implementation of chemical reactions in the central-upwind scheme's perspective is not so straightforward (to me).
Thank you anyway for your help.
Tommy
reactingfoam, transonic
reactingFoam crashes with no iterations uckmhnds OpenFOAM Running, Solving & CFD 3 July 17, 2022 18:41
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 15:31
Transonic simulation with reactingFoam ? lfgmarc OpenFOAM Running, Solving & CFD 0 July 19, 2011 00:58
reactingFoam wedge handling wrong U dhondupant OpenFOAM Bugs 1 December 9, 2010 07:34
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 12:57
