mapField: only map velocity
Old   April 3, 2020, 10:24
Default mapField: only map velocity
K.C. is on a distinguished road
Dear Foamers,
does anybody of you have an idea how to map ONLY the velocity field to my target case? All other fields shoudl not be mapped. I looked through mapFields -help, but found no option that could help. Maybe someone have ever tried this?
Kind regards,
K.C.
K.C. is offline   Reply With Quote
Old   April 3, 2020, 16:41
Luis Eduardo
lebc is on a distinguished road
Hi K.C.
In the description of mapFields.C you can see that:
Description
Maps volume fields from one mesh to another, reading and
interpolating all fields present in the time directory of both cases.
Parallel and non-parallel cases are handled without the need to reconstruct
them first.
My guess is that if you just want to map the velocity field, just delete the other fields from your target time folder, keeping just the U file. I haven't tested it, it is just a guess.
Best Regards,
Luis
lebc is offline   Reply With Quote
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation mykkujinu2201 Main CFD Forum 1 August 12, 2017 13:15
Superimposing 2 Velocity fields For Model inputs in Comsol f.black COMSOL 0 August 2, 2017 09:35
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
