Modelling sessile droplet sitting on the wall
Old   June 8, 2020, 06:21
Default Modelling sessile droplet sitting on the wall
Huihui Xiao is on a distinguished road
I try to model a sessile droplet sitting on the substrate with a initial contact angle e.g. 90 deg in interFoam. I was inspired by the following method:
walls
type constantAlphaContactAngle;
theta0 90;
limit gradient;
value uniform 0;
Actually, I tried to put a semi-spherical droplet on the substrate, and the centre of the semi-spherical droplet is just on the surface of the substrate, however, my droplet tends to spread on the surface.
I tried the second approach, I have a spherical droplet just over the surface for a certain distance, and it falls gradually, the droplet first spread over the surface and retrieve. After several time steps, it forms a contact angle of 90 deg finally.
Honestly, in my simulation, I do not need the initial spreading and retrieve process, I just need a sessile droplet with a certain contact angle. Could you please tell me how to do this?
Regards
Huihui Xiao is offline   Reply With Quote
contact angle, droplet, interfoam
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 11:55
[mesh manipulation] mergeMeshes problem Attesz OpenFOAM Meshing & Mesh Conversion 3 July 29, 2015 04:15
Modelling droplet flows in separators Jayne FLUENT 0 June 3, 2012 20:07
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
