August 14, 2020, 02:52 |
MapFields patches
Simon
Rep Power: 6 |
Hello everyone.
I am trying to use mapFields to interpolate the Fields from one case to another. My basic case is just a cube (6 Walls) and a fiber with small diameter inside going through the whole cube from Y+ to Y-. In further cases the fiber can have a larger diameter but I want the same U-Field. What I did is: - meshing all cases - solving the basic Case with simpleFoam - using mapFields like this: mapFields -sourceTime 'latestTime' ../3_case_SFE/ I am not using the -consistent optien because everything except the pipe is the same. Code:
Source: "..." Target: "..." Create databases as time Source time: 400 Target time: 0 Create meshes Source mesh size: 179982 Target mesh size: 190634 --> FOAM Warning : From function Foam::meshToMesh0::meshToMesh0(const Foam::fvMesh&, const Foam::fvMesh&, const Foam::HashTable<Foam::word>&, const wordList&) in file meshToMesh0/meshToMesh0.C at line 90 Cannot find cutting-patch <fiber_fine> in destination mesh Mapping fields for time 400 interpolating p --> FOAM Warning : From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = double; Foam::label = int] in file /home/ubuntu/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/Field.C at line 232 Reading "/.../50_3_caseTest/0/p.boundaryField.maxY" from line 46 to line 48 expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0. #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #4 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #5 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #6 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #7 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/mapFields" Speicherzugriffsfehler (Speicherabzug geschrieben) - I can see it wants to have a cutting-patch called fiber_fine. Fiber_fine is here the name of my stl-Geometry. But I can not make this patch because it is a complicated geometry. How can I make this? - What does it mean if it expects the keyword 'uniform' or 'nonuniform'? Thank you Simon Last edited by SimonStar; August 17, 2020 at 04:48. |
mapfields fiber error |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 08:19 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
[blockMesh] Merging edge patches | Yosmcer | OpenFOAM Meshing & Mesh Conversion | 11 | November 16, 2014 14:51 |
