Incompressible Flow Pre-Processing
Old   August 28, 2020, 03:39
Default Incompressible Flow Pre-Processing
Bobby
drdopamine is on a distinguished road
Hello all,
My name is Bobby and I work for a company that does Model / Hobbyist rockets. I'm trying to learn openFOAM to improve some of the content I can make for them.
I have no educational background in this field, and prior to this I'd never even opened linux.
Anyway, on to what I am trying to do. I intend to use an incompressible flow solver to analyze a model rocket (specifically a modified X-15).
I've duplicated the motorbike tutorial and created my own case. I've taken an .obj of the X15 and compressed it to match the format (.obj.gz), then replaced that with the root motorbike.obj.gz.
Then I ran the Allrun. I know, ignorant / wishful thinking.
I'm an amature, but it would appear to error out during the reconstructPar sequence, and according to the log
From function int main(int, char**)
in file reconstructPar.C at line 256
No times selected
However I cannot find reconstructPar.C anywhere in the case. This, I believe is my first problem?
Through further research I can tell I am also going to need to edit the blockMeshdict, as the .obj for the X15 is to scale dimensions, being FAR smaller than the motorbike. When looking into the blockMeshdict, I can see a series of vertices, blocks and boundaries that I imagine make up a rectangular prism similar to a windtunnel.
Is there an easy way to scale this down? Or a resource you can point me to which can define everything I am looking at? I checked the users-guide but to no avail (maybe I just couldn't find it?)
Lastly, what else am I overlooking? I'm sure there are other things. If there are barriers you forsee ahead of me, I'd love to know.
Thanks so much for your time.
drdopamine is offline   Reply With Quote
Old   September 3, 2020, 05:32
anonymous
simrego is on a distinguished road
Hi!
Based on your post I think you should start here:
https://cfd.direct/openfoam/user-guide/
There are some chapters about coding and I think you can skip this part. But you should at least run through the whole doc once. So you will have an idea what's happening and what is the "methodology" behind OpenFOAM.
BTW scale what? The background mesh? In the blockMeshDict you have a scale entry. But you can also scale the final mesh which is the result of snappyHexMesh with the transformPoints utility.
simrego is offline   Reply With Quote
Problem with incompressible flow amrrhm CONVERGE 2 July 12, 2016 09:18
starting compressible flow from incompressible flow results mihaipruna OpenFOAM Running, Solving & CFD 2 December 3, 2012 10:02
Reynold's number and incompressible flow Neil Main CFD Forum 3 October 24, 2006 08:11
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
AMR with Incompressible Flow Shahriar Main CFD Forum 7 March 7, 2003 08:53
