May 14, 2020, 08:05 |
Error "elements not defined in..."
Rep Power: 6 |
Please, could someone help me with explanation of this error:
Selecting chemistryReader foamChemistryReader elements not defined in "/mnt/c/Users/David/downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING/constant/reactions.air". I have described the reactions.air file based on the bubbleColumnEvaporatingReacting tutorial which is inside RAS directory of a reactingTwoPhaseEulerFoam tutorials. The description is as follows: species ( NO NH3 O2 N2 H2O AIR ); reactions { waterGasShift { type reversibleArrheniusReaction; reaction "NO^4 + NH3^4 + O2^1 = N2^4 + H2O^6"; A 3.85e6; beta 0; Ta 0.6764e4; } } I am trying to run the simulation using reactingTwoPhaseEulerFoam for a fluidised bed reactor. Although it names "reacting" There is no chemistry inside, so I am trying to add chemistry files from bubbleColumnEvaporatingReacting and change them according to my case. Thank you in advance for any help. |
May 20, 2020, 18:12 |
Herpes Free Engineer
Rep Power: 12 |
- Is there any chance for you to attach the `entire` log file, please, including the error?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 21, 2020, 02:15 |
Rep Power: 6 |
Thanks for you reply.
Now I have passed through this problem and I have another problem the reason of which is not clear for me as well: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _f3950763fe-20191219 OPENFOAM=1912 Arch : "LSB;label=32;scalar=64" Exec : reactingTwoPhaseEulerFoam Date : May 20 2020 Time : 19:52:24 Host : LAPTOP-LTH2ON9V PID : 2578 I/O : uncollated Case : /mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Reading g Reading hRef Creating phaseSystem Selecting twoPhaseSystem interfaceCompositionPhaseChangeTwoPhaseSystem Selecting phaseModel for air: reactingPhaseModel Selecting diameterModel for phase air: isothermal Selecting thermodynamics package { type heRhoThermo; mixture reactingMixture; transport sutherland; thermo janaf; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Selecting chemistryReader foamChemistryReader elements not defined in "/mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn/constant/reactions.air" Calculating face flux field phi.air Selecting turbulence model type laminar Selecting laminar stress model Stokes Selecting combustion model PaSR Selecting chemistry solver { solver EulerImplicit; method standard; } StandardChemistryModel: Number of species = 7 and reactions = 1 using integrated reaction rate Selecting phaseModel for particles: purePhaseModel Selecting diameterModel for phase particles: constant Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo eConst; equationOfState perfectFluid; specie specie; energy sensibleInternalEnergy; } Calculating face flux field phi.particles Selecting turbulence model type RAS Selecting RAS turbulence model phasePressure phasePressureCoeffs { preAlphaExp 500; expMax 1000; alphaMax 0.62; g0 1000; } No MRF models present Selecting default blending method: linear Selecting heatTransfer blending method: linear Selecting massTransfer blending method: linear Selecting surfaceTensionModel for (air and particles): constant Selecting aspectRatioModel for (particles in air): constant Selecting dragModel for (particles in air): GidaspowErgunWenYu Selecting swarmCorrection for (particles in air): none Selecting swarmCorrection for (particles in air): none Selecting swarmCorrection for (particles in air): none Selecting virtualMassModel for (particles in air): constantCoefficient Selecting virtualMassModel for (air in particles): constantCoefficient Selecting heatTransferModel for (particles in air): RanzMarshall Selecting heatTransferModel for (air in particles): spherical Selecting heatTransferModel for (particles in air): spherical Selecting heatTransferModel for (air in particles): RanzMarshall davyd@LAPTOP-LTH2ON9V:/mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn$ After that simulation is stopped. Maybe you can help with this issue. |
May 21, 2020, 02:39 |
Rep Power: 6 |
When I adjust the phaseProperties file in another way I got such king of error:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _f3950763fe-20191219 OPENFOAM=1912 Arch : "LSB;label=32;scalar=64" Exec : reactingTwoPhaseEulerFoam Date : May 21 2020 Time : 09:37:11 Host : LAPTOP-LTH2ON9V PID : 2616 I/O : uncollated Case : /mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn_Copy_2020-05-20 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Reading g Reading hRef Creating phaseSystem Selecting twoPhaseSystem interfaceCompositionPhaseChangeTwoPhaseSystem Selecting phaseModel for particles: purePhaseModel Selecting diameterModel for phase particles: constant Selecting thermodynamics package { type heRhoThermo; mixture multiComponentMixture; transport const; thermo eConst; equationOfState rhoConst; specie specie; energy sensibleInternalEnergy; } Calculating face flux field phi.particles Selecting turbulence model type RAS Selecting RAS turbulence model phasePressure phasePressureCoeffs { preAlphaExp 500; expMax 1000; alphaMax 0.62; g0 1000; } Selecting phaseModel for air: reactingPhaseModel Selecting diameterModel for phase air: isothermal Selecting thermodynamics package { type heRhoThermo; mixture reactingMixture; transport const; thermo eConst; equationOfState rhoConst; specie specie; energy sensibleInternalEnergy; } Selecting chemistryReader foamChemistryReader elements not defined in "/mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn_Copy_2020-05-20/constant/reactions.air" Calculating face flux field phi.air Selecting turbulence model type laminar Selecting laminar stress model Stokes Selecting combustion model PaSR Selecting chemistry solver { solver EulerImplicit; method standard; } StandardChemistryModel: Number of species = 7 and reactions = 1 using integrated reaction rate No MRF models present Selecting default blending method: none Selecting surfaceTensionModel for (particles and air): constant Selecting aspectRatioModel for (particles in air): constant Selecting aspectRatioModel for (air in particles): constant Selecting dragModel for (particles in air): GidaspowErgunWenYu Selecting swarmCorrection for (particles in air): none Selecting swarmCorrection for (particles in air): none Selecting swarmCorrection for (particles in air): none Selecting virtualMassModel for (particles in air): constantCoefficient Selecting heatTransferModel for (particles in air): spherical Selecting heatTransferModel for (particles in air): RanzMarshall Selecting interfaceCompositionModel for (particles in air): saturated<heRhoThermo<multiComponentMixture<const< eConst<rhoConst<specie>>,sensibleInternalEnergy>>> ,heRhoThermo<reactingMixture<const<eConst<rhoConst <specie>>,sensibleInternalEnergy>>>> Selecting saturationModel: ArdenBuck Selecting massTransferModel for (particles in air): spherical Selecting massTransferModel for (particles in air): Frossling Calculating field g.h Reading field p_rgh Courant Number mean: 0.00287522 max: 0.003295 Starting time loop fieldAverage fieldAverage1: Restarting averaging for fields: U.particles: starting averaging at time 0 U.air: starting averaging at time 0 alpha.particles: starting averaging at time 0 p: starting averaging at time 0 Courant Number mean: 0.00287522 max: 0.003295 Max Ur Courant Number = 0.003295 Time = 0.0002 PIMPLE: iteration 1 MULES: Solving for alpha.particles MULES: Solving for alpha.particles alpha.particles volume fraction = 0.129996 Min(alpha1) = 0 Max(alpha1) = 0.52 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libc.so.6 #3 Foam::InterfaceCompositionModel<Foam::heRhoThermo< Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::multiComponentMixture<Fo am::constTransport<Foam::species::thermo<Foam::eCo nstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >, Foam::heRhoThermo<Foam::rhoReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::co nstTransport<Foam::species::thermo<Foam::eConstThe rmo<Foam::rhoConst<Foam::specie> >, Foam::sensibleInternalEnergy> > > > > >:(Foam::word const&) const at ??:? #4 Foam::InterfaceCompositionPhaseChangePhaseSystem<F oam::PhaseTransferPhaseSystem<Foam::TwoResistanceH eatTransferPhaseSystem<Foam::MomentumTransferPhase System<Foam::twoPhaseSystem> > > >::massTransfer() const at ??:? #5 ? at ??:? #6 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #7 ? at ??:? Segmentation fault (core dumped) davyd@LAPTOP-LTH2ON9V:/mnt/c/Users/David/Downloads/OpenFOAM/OpenFOAM-v1912/RUN/fluidisedBed_REACTING_bcolumn_Copy_2020-05-20$ |
November 19, 2020, 22:22 |
xubing
HI,Davyd
although i havnt see you constant/reactions.air flie I think in this flie you havnt put element in first like this —— elements ( O C H N ); species ( O2 H2O CH4 CO2 N2 ); reactions { methaneReaction { type irreversibleArrheniusReaction; reaction "CH4 + 2O2 = CO2 + 2H2O"; A 5.2e16; beta 0; Ta 14906; } } you can see how to define element in Openfoam web mybe i am wrong , hahaha |
[Other] a field defined only selected cells and solving an equation on selected cells | ashish.svm | OpenFOAM Meshing & Mesh Conversion | 0 | June 27, 2017 11:14 |
User defined memory value changing | minhoabc | FLUENT | 2 | June 22, 2017 06:28 |
Not defined orientation change while running SU2_CFD | mdawson25 | SU2 | 4 | May 11, 2017 09:52 |
why CPtr_ defined as SlicedGeometricField, whereas magSfPtr_ as GeometricField? | Jerryfan | OpenFOAM Programming & Development | 1 | July 6, 2016 21:02 |
fetal overflow in user defined cavitation model | unclewallcn | CFX | 15 | January 20, 2016 22:17 |
