January 13, 2021, 08:47 |
BC for a swirl diffuser
Rep Power: 7 |
I am simulating a room with swirl diffuser like in the image; and I have some doubt on how to implement the BC. I would appreciate your help, if you could help me these are my doubts: I think the best way to simulate the diffuser downstream airflow is to use "swirlFlowRateInletVelocity" BC, or is there a better way? In case this BC is correct, <patchName> { type swirlFlowRateInletVelocity; flowRate constant 0.2; rpm constant 100; } assuming that i know the flowrate, and so the normal velocity component, and the tangential velocity component (calculated from measured magnitude velocity) what rpm value should I use? I have not found the formula to calculate rpm My boundary surface includes all 24 slites, so it is 1 entity, I assume the swirl obtained is one "big" swirl, like in the image, and not 24 little swirles one for each slite, is it correct? |
January 14, 2021, 16:34 |
Rep Power: 7 |
I found the answer, RPM is the fluidflow rpm not the rpm of a hypothetical fan, so the tangential velocity is equal to RPM*PI/30 (conversion RPM to rad/s) * radius (distance from boundary surface center). And in this case it creates one big swirl per diffuser
UDF for a swirl diffuser | Chris1590000 | Fluent UDF and Scheme Programming | 0 | January 23, 2019 01:35 |
Swirl Flow in a conical diffuser | fhabbio | Main CFD Forum | 0 | February 12, 2017 19:08 |
Quantifying the swirl in CFX, Swirl Number/Swirl Angle | tauqirnawaz | CFX | 23 | July 24, 2016 22:28 |
Swirl diffuser flow | lpy2009 | FLUENT | 2 | January 8, 2015 02:20 |
Quantifying Swirl | Ianto | Main CFD Forum | 0 | April 27, 2009 10:54 |
