February 2, 2021, 06:58 |
FOAM FATAL IO ERROR using Helyx OS v2.4.0
Lucas Pelchen
Rep Power: 5 |
OpenFOAM-version: 8
HelyxOS-version: v.2.4.0 During the Field Initialisation of the perpared simulation (to be found in the attachment) some problem with the velocity data of the outlet has appeared. See the following information of the terminal window inside the helyx -application: 0] --> FOAM FATAL IO ERROR: [0] size 0 is not equal to the given value of 51 [0] [0] file: /home/lucas/Test/Test/processor0/0/U/boundaryField/Auslauf from line 8416 to line 8417. [0] [0] From function Foam::Field<Type>::Field(const Foam::word&, const Foam::dictionary&, Foam::label) [with Type = Foam::Vector<double>; Foam::label = int] [0] in file /home/ubuntu/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/Field.C at line 210. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0 with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- For the settings of the different menus of the helyx-application I used this video as a reference: https://www.youtube.com/watch?v=2cywdPboXyw Many thanks in advance p { margin-bottom: 0.1in; line-height: 115%; background: transparent }a:visited { color: #800000; text-decoration: underline }code.western { font-family: "Liberation Mono", monospace }code.cjk { font-family: "Noto Sans Mono CJK SC", monospace }code.ctl { font-family: "Liberation Mono", monospace }a:link { color: #000080; text-decoration: underline } |
helyx-os |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
