compressibleInterFoam 6.0 equationOfState parameters
Old   January 13, 2022, 20:02
Default compressibleInterFoam 6.0 equationOfState parameters
Josh McCraney
joshmccraney is on a distinguished road
Hi All
I am running compressibleInterFoam 6.0 on Ubuntu 18.04. In the constant/thermophysicalProperties.water file looks like:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    properties      liquid;
    energy          sensibleInternalEnergy;
mixture
    H2O;
thermoType
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    equationOfState perfectFluid;
    specie          specie;
mixture
    specie
        molWeight   118.0;
    equationOfState
        R           3000;		//	J / (kg K)
        rho0        840;		//	DENSITY AT T = 0
    thermodynamics
        Cp          1510;		//	ABOUT 1/3 OF WATER
        Hf          0;			//
    transport
        mu          0.0017;		// JMC
        Pr          23.;		// JMC K = 0.11
which is very similar to the depthCharge2D tutorial. The two fluids I am using are air and 2 centistoke silicone oil at room temperature. I am trying to assess what R should be in equationOfState. Since this is not a gas, I'm unsure the value. Here are the units of R, know as the fluid constant. Sure looks like specific heat, but I believe that is specified in thermodynamics under Cp. So I'm confused. Any help is greatly appreciated.
For what it's worth, the perfectFluid seems to follow the equation $\rho = p/(RT) + \rho_0$.
joshmccraney is offline   Reply With Quote
Solver parameters to solve convergence issue WilliamH SU2 5 February 5, 2021 06:19
Parameters of a good airfoil mesh CharlieBra7o Mesh Generation & Pre-Processing 4 November 20, 2018 14:42
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 05:52
Ahmed body simulation gives unexpected results in su2 6.0 anas651 SU2 0 March 28, 2018 03:42
Parameters rhoSimpleFoam marcus85 OpenFOAM Pre-Processing 0 May 15, 2013 09:36
