May 10, 2021, 22:44 |
inlet boundary conditions inside domain
yan
Rep Power: 5 |
Hi, I was running a simulation of a burner in the center of the domain.
The burner was extruded with two patches. The goal is to set a fuel inlet boundary condition on the bottom patch side. For the burner, the top patch velocity is set to zero, and the bottom patch is set with "flowRateInletVelocity" with a positive mass flow rate. To my surprise, in the results, although most combustion occurs on the bottom patch side which is reasonable, some of the combustions indeed occur below the burner (on the top patch side). Since I was trying to set the top patch as a wall, it is not reasonable to see fuel on this side So I am wondering if the "flowRateInletVelocity" allows flow across it? And anyone could help and suggest a reasonable boundary condition for the burner |
inlet boundary condition, wall boundary condition |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
