June 9, 2021, 08:37 |
shear stress utility
hulli graemer
Rep Power: 11 |
Hi guys,
what are the units of the shear stress fields one can post-process in OF8 ? m2/s2 ??? Thanks |
June 10, 2021, 13:10 |
Rep Power: 14 |
Depends on the solver. If it's a kinematic solver, like simpleFoam, then viscosity, pressure and other stresses are kinematic. So shear stress will have units m2/s2. If you are running a compressible solver, then it won't be kinematic and you will have the regular units of kg/m.s2.
PS - a simple check is to look at the tutorial for the solver, and check the units in the boundary files. |
June 11, 2021, 04:42 |
thank
hulli graemer
Rep Power: 11 |
... thank you so much that helps a lot ...
How to obtain fluid shear stress (not only wall shear stress) in openFOAM | sourav90 | OpenFOAM Programming & Development | 8 | June 27, 2023 10:03 |
Shear Stress Calculation in the flow. | auburnuser | FLOW-3D | 11 | May 12, 2018 13:49 |
Cannot achieve negative wall shear stress values in CFD Post (ANSYS) | SAtkins | CFX | 3 | August 3, 2016 14:27 |
shear stress scalar definitions? | Novak Elliott | CFX | 0 | April 6, 2003 01:45 |
What is the detail definition of wall shear stress | zjm | FLUENT | 0 | January 2, 2002 07:43 |
