codedFixedValue not assigning values to the inlet
Old   October 13, 2021, 11:49
Default codedFixedValue not assigning values to the inlet
Legacy is on a distinguished road
I'm new to OpenFOAM and trying to simulate a flow in a channel to learn OpenFOAM. I'm running multiphase (water and air) case so I would like to assign flowrate where alpha.water is 1 (which is z<=0.8 in my case. I used the following code in my 0/U file but nothing is happening to the model. Can someone who has experience with codedFixedValue chime in on this? I would appreciate the help. Thanks.
Here in the inlet BC from 0/U file
inlet
        type            codedFixedValue;
        value           uniform (0 0 0);
        name            inletBC;
        code
                const fvPatch& boundaryPatch = patch();
                const vectorField& Cf = boundaryPatch.Cf();
                vectorField& field = *this;
                forAll (Cf, faceI) // loop over all the patch faces
                    const scalar x = Cf[faceI].x(); // y coordinate of the face
                    const scalar y = Cf[faceI].y(); // y coordinate of the face
                    const scalar z = Cf[faceI].z(); //  y coordinate of the face
                    if (z <= 0.80 && y <= 2 && x <=0.1 )
                        field[faceI] = vector(1, 0, 0);
                    else
                    field[faceI] = vector (0, 0, 0);
Legacy is offline   Reply With Quote
codedfixedvalue, interfoam, openfoam
Assigning values from 2d double array to Field<Type> yousefaz OpenFOAM Programming & Development 0 June 2, 2021 20:23
Assigning values to read-only location saumavadey OpenFOAM Running, Solving & CFD 0 February 10, 2021 08:20
How can we use dimensionless values as inlet and out let BC? granzer FLUENT 3 November 7, 2019 23:29
Assigning values to a cartesian grid from a binary image (or stl) Cyp OpenFOAM Pre-Processing 1 August 5, 2014 18:02
units for inlet values of contaminant in star-ccm+ judge Siemens 0 August 13, 2008 07:29
