July 25, 2022, 10:27 |
temperature in impeller blade SRF
yasmine
Rep Power: 3 |
hello foamers,
I have made a simulation of an impeller blade of a centrifugal air compressor in openfoam with the SRFsimplefoam solver but I want to integrate the temperature. Therefore, I tried to create a T temperature file but it didn't work. Could you please help me with this? Thanks in advance. T temperature file : internalField uniform 293; boundaryField { inlet { type fixedValue; value uniform 293; } outlet { type fixedValue; value uniform 293; } wall_moyeu { type fixedValue; value uniform 293; } wall_carter { type fixedValue; value uniform 293; } wall_moyeu_glissant { type fixedValue; value uniform 293; } wall_carter_glissant { type fixedValue; value uniform 293; } cyclic_d { type fixedValue; value uniform 293; } cyclic_g { type fixedValue; value uniform 293; } pale { type fixedValue; value uniform 293; } } // ************************************************** *********************** // |
How to split air blade in CFX Post without loosing accuracy | JonasII | CFX | 7 | May 18, 2021 16:54 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
What's the highest turbine inlet temperature in the modern gas turbine blade ? | FastFlow | Main CFD Forum | 4 | October 9, 2016 14:01 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 22:43 |
