August 4, 2022, 04:42 |
No MRF models present.
Sangho Ko
Rep Power: 4 |
Hello everyone~
I'm newbie of OpenFOAM and I got a problem. I've generated CFD but it doesn't work. I've found that "No MRF models present" but I don't know why this occurs. Can you guys check my file? Below is my Github link. https://github.com/fluidko/lecture-49-50 Thank you |
August 4, 2022, 05:41 |
Yann
Rep Power: 26 |
Hi Sangho Ko,
No MRF models present is not an error, it's just telling you there is no MRF model in your case. (it could be an error if you intended running your case with MRF). Same goes for the No finite volume options present. You actual problem is located in the controlDict file: Code:
application pimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1e-5; deltaT 0.025; Regards, Yann |
August 4, 2022, 06:00 |
#3 | |
Sangho Ko
Rep Power: 4 |
Thank you for your help! |
simpleFoam: Influence of MRF region dimensions on simulation results | Krao | OpenFOAM Running, Solving & CFD | 4 | March 29, 2022 21:33 |
[mesh manipulation] MRF zone enclosed in another MRF zone | Dikkeunit | OpenFOAM Meshing & Mesh Conversion | 0 | November 25, 2021 14:08 |
Modeling Wheel Rotation using MRF | Lukas7117 | Main CFD Forum | 0 | December 1, 2020 10:03 |
Can the MRF and porousZone models be combined in one zone? | erlofg | OpenFOAM Running, Solving & CFD | 6 | April 11, 2016 05:37 |
Incompressible Turbulence models | achinta | OpenFOAM | 4 | May 27, 2010 10:35 |
