totalPressure Error
Old   August 10, 2022, 06:30
Default totalPressure Error
Matthew
Tegdlemat is on a distinguished road
Hi everyone,
I am currently attempting to simulate a shock train phenomenon as shown in the first picture with rhoCentralFoam. In my case, I require a inlet pressure at 47000pa and outlet pressure at 104000pa, with inlet Mach number at 1.61 and temperature at 197K. I am using the boundary conditions below for the simulation, and the pressure at the inlet matches the target pressure magnitude, but not at the outlet. I wonder if I implied the totalpressure wrongly that causes the pressure there basically equals to the total pressure I defined. I have included the pressure contour as the second picture. I would be very grateful if anyone could lend my a helping hand.
0/p
dimensions      [1 -1 -2 0 0 0 0];
internalField     uniform 47984;
boundaryField
    Inlet
        type           totalPressure;
        p0              uniform 207000;
        gamma      1.4;
        psi              thermo:psi;
        value          uniform 47984;
    Outlet
        type           totalPressure;
        p0              uniform 451260;
        gamma      1.4;
        psi              thermo:psi;
        value          uniform 104859;
    Wall
        type            zeroGradient;
    Sides
        type            empty;
0/T
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 197.6;
boundaryField
    Inlet
       type            fixedValue;
       value          uniform 197.6;
    Outlet
        type            zeroGradient;
    Wall
        type            zeroGradient;
    Sides
        type            empty;
0/U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (453.65 0 0);
boundaryField
    Inlet
        type            pressureInletOutletVelocity;
        value           $internalField;
    Outlet
    Wall
         type            noSlip;
    Sides
        type            empty;
Tegdlemat is offline   Reply With Quote
Old   October 29, 2022, 08:04
Sakun
Sakun is on a distinguished road
Did you manage to sort this out ?
Sakun is offline   Reply With Quote
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
