Macro expression in OpenFOAM 10
Like Tree3Likes
  • 1 Post By kakila
  • 2 Post By tniemi
Old   November 3, 2022, 12:17
Default Macro expression in OpenFOAM 10
Agustín Villa
agustinvo is on a distinguished road
Hi all,
I am trying to run the airfoil case of Sebastiano Stipa using OpenFOAM v10, however when I run blockMesh I get an error related with the macro expansion:
Creating block mesh from
    "system/blockMeshDict"
--> FOAM FATAL IO ERROR:
Illegal dictionary entry or environment variable name ":aerofoil.xUpper"
Valid dictionary entries are 1(type)
As far as I know, there is a bug related to this (link), where they complain about the wrong indications at the User Guide. Nevertheless, I'm trying different configurations but I always get the same error.
I have run blockMesh successfully with OpenFOAM v7 so I suppose that something has changed on the Macro expansion declaration but it is not clear the new formulation.
Has someone found a solution or walkaround to this problem?
Regards
Agustín
agustinvo is offline   Reply With Quote
Old   November 7, 2022, 06:35
Kasper
KasperWayne is on a distinguished road
Take a look at the documentation for OF10 and you can see the difference :-)
https://doc.cfd.direct/openfoam/user...17-1320004.2.9
KasperWayne is offline   Reply With Quote
Old   November 7, 2022, 10:21
Agustín Villa
Well, that is actually the bug I linked in the first post. It is said that there are mistakes on the macro definition.
If you check in the OF v7 documentation the same section, you will see that the sole difference is the 'slash' introduction in OF v10, and after that the 'dot' formulation is always applied.
If the contents of the Macro Expansion are mostly, why can't I run it properly? If there are changes, they are not correctly indicated in the documentation.
Old   November 21, 2022, 05:19
Juan Pablo Carbajal
kakila is on a distinguished road
I can confirm this. I have a set of parametrized files and they are not working anymore in OF10.
It seems that there is an undocumented change in the macro expansion.
Anybody knows what is this change?
Also the "/" (dot) in the documentation is also a bug. It is a dot or a slash? In OF10 it seems it is a slash https://bugs.openfoam.org/view.php?id=3877.
Update:
Form that bug: the dot notation is deprecated (not working in OF10).
Looking at the source code:https://cpp.openfoam.org/v10/diction...ce.html#l00897
I found that for the slash notation (what you need to use in OF10) the references to other levels also change (undocumented). so root level for slash notation is "!" not ":".
I cannot find whether the relative scopes (use of "..") are valid for the slash notation, it is not transparent from the source code.
agustinvo likes this.
kakila is offline   Reply With Quote
Old   November 22, 2022, 02:29
Timo Niemi
tniemi is on a distinguished road
The new slash syntax is documented in this commit message: https://github.com/OpenFOAM/OpenFOAM...3519b0d187e485
The documentation for OF10 is not yet fully updated and a bit confusing.
The reason for this change was to add flexibility and eg. support easily referring to entries which contain a dot (typical for multiphase simulations).
It is still possible revert to using the old syntax, either globally by editing etc/controlDict or locally case by case.
agustinvo and kakila like this.
tniemi is offline   Reply With Quote
Old   February 16, 2023, 05:54
Agustín Villa
Thank you! I have been busy with other bussiness but I have checked your comment and it works!
Old   April 15, 2024, 05:03
moh raafat is on a distinguished road
I have the same issue, and tried to modify the syntax but in vain, can you provide exactly the required modification to the file.
Thanks in advance
moh raafat is offline   Reply With Quote
Old   April 15, 2024, 09:43
Timo Niemi
I have not run the case, but I just checked and basically to run blockMesh, do the following changes:
domain. -> domain/
aerofoil. -> aerofoil/
So for example
$:aerofoil.xUpper -> $!aerofoil/xUpper
and a bit longer snippet:
geometry
aerofoil
type triSurfaceMesh;
file "NACA0012.obj";
cylinder
type searchableCylinder;
point1 ($!aerofoil/xUpper -1e3 0);
point2 ($!aerofoil/xUpper 1e3 0);
radius $!domain/zMax;
vertices
project ($aerofoil/xLower -0.1 $domain/zMin) (cylinder)
($aerofoil/xTrail -0.1 $domain/zMin)
($domain/xMax -0.1 $domain/zMin)
Old   April 17, 2024, 04:11
thanks a lot, it works for blockeMesh, noting that the there other syntax errors for version s OF9 and OF10 included in the mentioned tutorials due to syntax changes, such as functions part in controlDict file, I will try generate the entire tutorial and make updates.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 05:57
Modifying CFD-Post macro to output a time-varying expression at every timestep lynnathere CFX 0 December 28, 2015 16:19
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
