setFields alpha.water inclusive AMI
Old   January 7, 2024, 15:33
Default setFields alpha.water inclusive AMI
Volkan Atar
Volkanatar is on a distinguished road
Hello Foamers,
i have an interfoam case for kind of mixing process. I'm using setFields with surfaceToCell method (using a external .stl file) in the setFieldsDict:
defaultFieldValues
volScalarFieldValue alpha.water 0
regions
surfaceToCell
file setfields.stl;
outsidePoints (( 0.0 0.0 0.27 ));
includeCut true;
includeInside true;
includeOutside false;
nearDistance 0.01;
curvature 1;
fieldValues
volScalarFieldValue alpha.water 1
My AMI region is staying inside the setfields.stl and after executing the setFields the AMI-region is not "filled" with water. only the volume between AMI region and setfields.stl is being filled. Is there a way to fill also AMI region with water ?
Thanks in advance.
Volkanatar is offline   Reply With Quote
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 457 March 27, 2024 00:59
multiphaseEulerFoam FOAM FATAL IO ERROR qutadah.r OpenFOAM Running, Solving & CFD 11 December 10, 2021 20:18
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 22:35
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 14:05
