Volkan Atar
Rep Power: 4 ![]() |
Hello Foamers,
i have an interfoam case for kind of mixing process. I'm using setFields with surfaceToCell method (using a external .stl file) in the setFieldsDict: defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( surfaceToCell { file setfields.stl; outsidePoints (( 0.0 0.0 0.27 )); includeCut true; includeInside true; includeOutside false; nearDistance 0.01; curvature 1; fieldValues ( volScalarFieldValue alpha.water 1 ); } ); My AMI region is staying inside the setfields.stl and after executing the setFields the AMI-region is not "filled" with water. only the volume between AMI region and setfields.stl is being filled. Is there a way to fill also AMI region with water ? Thanks in advance. |
#2 | |
Nick
Rep Power: 5 ![]() |
You may use additional boxtoCell and boxtoFace regions to fill the remaining regions.
Display Modes | |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 459 | September 12, 2024 12:47 |
multiphaseEulerFoam FOAM FATAL IO ERROR | qutadah.r | OpenFOAM Running, Solving & CFD | 11 | December 10, 2021 21:18 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca | insane | OpenFOAM Running, Solving & CFD | 0 | May 17, 2020 23:35 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 15:05 |
