February 17, 2023, 00:14 |
AxiSymmetric Cylinder Model - OpenFoam
Khan
Rep Power: 7 |
I try to model the temperature transients for a sensible stratified heat storage tank by use of OpenFoam (see for details: cfd - online: Sensible Stratified Storage Tank). In order to generate mesh for axisymmetric geometry: I formed a 2D face which was later converted to a solid by applying revolution with 2.5 deg (around axis z) in Salome_Meca 2022.0.0. I built groups as with inlet, outlet, walls, diffuser (obstacle for flow at the inlet and outlet), and wedge_1 and wedge_2 (see the code text given at the bottom for the /constant/polyMesh/boundary). I generated the mesh with various approaches (i.e. by use of GMSH (built-in in Salome Meca), NETGEN) for trial purposes. I, then, export the mesh as Unv file from Salome Meca. Then I use the code in the Ubuntu Terminal "ideasUnvToFoam" and checked the mesh via "checkMesh". Everything is fine until here! Whenever I try to run my code via "buoyantFoam", I receive an error given below. Would you please help me to overcome this issue? Code:
--> FOAM FATAL ERROR: wedge wedge_1 plane aligns with a coordinate plane. The wedge plane should make a small angle (~2.5deg) with the coordinate plane and the pair of wedge planes should be symmetric about the coordinate plane. Normal of wedge plane is (0 -1 0) , implied coordinate plane direction is (0 -1 0) From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBuffers&) in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 110. Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 6 ( inlet { type patch; nFaces 9; startFace 191196; } outlet { type patch; nFaces 9; startFace 191205; } walls { type wall; nFaces 1476; startFace 191214; } diffuser { type empty; nFaces 846; startFace 192690; } wedge_1 { type wedge; nFaces 16854; startFace 193536; } wedge_2 { type wedge; nFaces 16854; startFace 210390; } ) // ************************************************************************* // |
February 17, 2023, 01:28 |
Khan
Rep Power: 7 |
The tar file for this OpenFoam case can be downloaded from: https://www.mediafire.com/file/9qwpw...ym.tar.gz/file
February 17, 2023, 02:19 |
Khan
Rep Power: 7 |
I solved the problem after watching some tutorials: if you have the same issue, you have to apply revolution (Salome Meca - New Entity \ Generation \ Revolution) with 2.5 deg for both directions so, as stated in the error, both of the wedges shall be symmetric about the coordinate plane!
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[mesh manipulation] 2D Axisymmetric Model in OpenFOAM 4.0 | m_ridzon | OpenFOAM Meshing & Mesh Conversion | 25 | March 29, 2023 04:11 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
OpenFOAM: LES turbulence model names | Ollie | Main CFD Forum | 1 | April 11, 2011 13:03 |
