February 21, 2023, 15:57 |
error in running airfoil2d tutorial files
shir levi
hello, i am trying to run the files of airfoil2d tutorial
but when I use the commend simpleFoam the following error appears: /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 9-c96968adf6d8 Exec : simpleFoam Date : Feb 21 2023 Time : 22:48:53 Host : "DESKTOP-212INEV" PID : 4929 I/O : uncollated Case : /home/shir/OpenFOAM/shir-9/run/airFoil2D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: Convergence criteria found p: tolerance 1e-05 U: tolerance 1e-05 nuTilda: tolerance 1e-05 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model SpalartAllmaras Selecting patchDistMethod meshWave RAS { RASModel SpalartAllmaras; turbulence on; printCoeffs on; sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cs 0.3; } No MRF models present No fvModels present No fvConstraints present Starting time loop --> FOAM FATAL IO ERROR: wrong token type - expected string, found on line 52 the word 'fieldFunctionObjects' file: /home/shir/OpenFOAM/shir-9/run/airFoil2D/system/controlDict/functions/momErr/libs at line 52. From function Foam::Istream& Foam:: operator>>(Foam::Istream&, Foam::fileName&) in file primitives/strings/fileName/fileNameIO.C at line 56. Ididn't change the files, how to fix it ? |
error- airfoil2d- |
[blockMesh] Corrupted files after running blockMesh or topoSet | javihernandez | OpenFOAM Meshing & Mesh Conversion | 2 | February 10, 2021 05:50 |
[OpenFOAM.org] Error running #codeStream/functions wmake lnInclude fails to open *.H Files | tarik | OpenFOAM Installation | 8 | June 14, 2020 03:12 |
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. | MBttR | OpenFOAM Running, Solving & CFD | 0 | June 13, 2016 10:58 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
