September 8, 2023, 16:23 |
decomposePar not repartitioning/mapping data
Emilian Popov
I'm trying to increase the partitions of an already partitioned case, and mapping the data on the new partitions. I use v2206.
I made some limited progress, but can't figure out the workflow. For some processors the mesh is placed in the constant folder, for others - in the time folders. I'm not sure I understand the -constant flag. I managed to go through a two-step process, first with numberOfSubdomains =1, and then one more step with the desired number of partitions, but the data from the last timestep are not mapped to the newly created partitions. Bottom line, if someone knows how to do that, please let me know what the workflow is thank you so much, Emilian |
decomposepar mapping data |
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam | MikeHersee | ParaView | 2 | January 6, 2015 08:27 |
Data Produced From Fine Marine Cant Match with The Experimental Data | PeiSan | Fidelity CFD | 4 | August 23, 2014 05:33 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 02:47 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
