Boat not rotating on roll axis
Old   September 14, 2023, 23:05
Default Boat not rotating on roll axis
volticshipping is on a distinguished road
Hi, Im stuck on this issue I've been having. I took the DTCHullWave case and want to simulate waves hitting the side of the hull so it can roll. I changed the setup so that the waves flow from inlet to outlet against a rotated version of the hull. I then added a joint in the dynamic mesh dict to allow the hull to roll along its center of mass lengthwise. However, when I run the simulation, the hull is still stationary, and the alpha.water looks super weird. I attached a picture to show. I also pasted my dynamic mesh dict below as well. Would appreciate any help
|  \\    /   O peration     | Version:  v2306                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolverLibs ("librigidBodyMeshMotion.so");
motionSolver    rigidBodyMotion;
report          on;
solver
    type Newmark;
accelerationRelaxation 0.4;
bodies
    hull
        type            rigidBody;
        parent          root;
        centreOfMass    (-5.288 29.582 -1.955);
        mass            345159.856;
        //inertia         (40 0 0 921 0 921);
       inertia         (1.118e8 0.299 0.011 0.299 5.963e6 -740826.865 0.011 -740826.865 1.156e8);
        transform       (1 0 0 0 1 0 0 0 1) (9.90268 -84.9027 0.0110973);
        joint
            type    composite;
            joints
                    type Pz;
                    type Ry;
        patches         (hull);
        innerDistance   0.3;
        outerDistance   1;
restraints
    translationDamper
        type linearDamper;
        body hull;
        coeff 8596;
    rotationDamper
        type sphericalAngularDamper;
        body hull;
        coeff 11586;
File Type: jpg Screen Shot 2023-09-14 at 11.01.40 PM.jpg (46.1 KB, 5 views)
volticshipping is offline   Reply With Quote
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 18:05
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 04:23
simulating a stationary axis gas turbine with blades fixed in a rotating shell lawbambace OpenFOAM 0 January 5, 2016 09:35
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
