September 14, 2023, 23:05 |
Boat not rotating on roll axis
Hi, Im stuck on this issue I've been having. I took the DTCHullWave case and want to simulate waves hitting the side of the hull so it can roll. I changed the setup so that the waves flow from inlet to outlet against a rotated version of the hull. I then added a joint in the dynamic mesh dict to allow the hull to roll along its center of mass lengthwise. However, when I run the simulation, the hull is still stationary, and the alpha.water looks super weird. I attached a picture to show. I also pasted my dynamic mesh dict below as well. Would appreciate any help
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2306 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("librigidBodyMeshMotion.so"); motionSolver rigidBodyMotion; report on; solver { type Newmark; } accelerationRelaxation 0.4; bodies { hull { type rigidBody; parent root; centreOfMass (-5.288 29.582 -1.955); mass 345159.856; //inertia (40 0 0 921 0 921); inertia (1.118e8 0.299 0.011 0.299 5.963e6 -740826.865 0.011 -740826.865 1.156e8); transform (1 0 0 0 1 0 0 0 1) (9.90268 -84.9027 0.0110973); joint { type composite; joints ( { type Pz; } { type Ry; } ); } patches (hull); innerDistance 0.3; outerDistance 1; } } restraints { translationDamper { type linearDamper; body hull; coeff 8596; } rotationDamper { type sphericalAngularDamper; body hull; coeff 11586; } } // ************************************************************************* // |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
simulating a stationary axis gas turbine with blades fixed in a rotating shell | lawbambace | OpenFOAM | 0 | January 5, 2016 09:35 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
rotating domain in rotating domain, different axis | Robert Stringer | CFX | 3 | December 4, 2006 07:04 |
