September 17, 2023, 18:18 |
Turbulence Properties
Anas Ayman
I am simulating a turbulent flow around an airfoil at Re = 6e+6 and Ma = 0.7 and I chose the turbulence model to be kOmega
I have several questions about the pre-processing part 1. What is the difference between nu and nut? and What property is needed in "0" file? 2. How to let OpenFOAM understand the Re? (How to enter Re into OpenFOAM)? 3. How to calculate "Omega"? 4. How to calculate "k"? |
September 18, 2023, 03:15 |
#2 | |||
Rep Power: 5 |
Hey
nu is the kinematic viscosity that should be used in transportProperties (assuming you use simpleFoam for instance) and nut is the turbulent viscosity, which is used in the 0 folder. Quote:
OpenFoam does not need to understand the Re, your boudary conditions will dictate it (your inlet velocity, your airfoil etc). Quote:
If you look around in the OpenFoam doc and online, you will find formulas to calculate the initial values depending on your fluid and your conditions. There is this online calculator if you want to compare values: http://ichrome.com/blogs/archives/342 Good luck! And search the forum too, you will find better and more complete answers than mine |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 12:16 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Material Properties for Sat. Liquid and Sat. Vapor | Blackhawks84 | FLUENT | 0 | September 17, 2012 19:11 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 17:15 |
Free air turbulence properties | Luis DÃaz | FLUENT | 0 | March 15, 2008 03:23 |
