setExprFields changing the BC
Old   February 8, 2024, 21:57
Default setExprFields changing the BC
Virag
virag.v.mishra@gmail.com is on a distinguished road
Hi
I wanted to provide hydrostatic pressure under a wave profile as an initial condition. I decided to use the setExprFields method.
My setExprFieldsDict looks like below
readFields ( alpha.water );
_WATERPRESS
target value;
expression #{ (alpha.water > 0.5 ? 1025*9.81*mag(pos().z() - 0.6) : 0) #};
dimensions [ kg m^-1 s^-2 ];
expressions
p_rgh
field p_rgh;
create yes;
$_WATERPRESS;
This does what it is intended to do except that it changes the BC from
.. ground inlet outlet sides top
p_rgh fixedFluxPressure fixedFluxPressure fixedFluxPressure empty totalPressure
To
p_rgh calculated calculated calculated empty calculated
How to change only the internal fields, not the BCs?
virag.v.mishra@gmail.com is offline   Reply With Quote
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 13:35
setExprFields example to generate an initial velocity field for LES of channel flow fumiya OpenFOAM Running, Solving & CFD 6 January 20, 2022 21:30
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 19:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
energy changing associated with mass changing Martin duan FLUENT 0 August 6, 2011 13:42
