Turbulent flow in a rectangular duct foam vs fluent
Old   January 29, 2006, 19:26
Default I am simulating a turbulent fl
atzaru
I am simulating a turbulent flow in a square duct (0.2*0.2*6) in foam and fluent. I am concern about the velocity distribution difference between the two programs.
Reynolds number around 11 000.
in fluent i obtain a max velocity around 1.24 while in Foam the max velocity is 1.14. Does anybody know why and how i can correct this?
in both programs i introduced the same inlet (velocity, V=1m/s), the same initial k and epsilon, and outlet condition.
turb_flow_v2.tar.gz
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default Gauss <>;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian(1|A(U),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
The boudary condition are:
wall
type wall;
physicalType wall;
startFace 97040;
nFaces 6720;
outlet
type patch;
physicalType pressureOutlet;
startFace 103760;
nFaces 400;
inlet
type patch;
physicalType inlet;
startFace 104160;
nFaces 400;
Old   January 30, 2006, 07:25
Default What does the experimental dat
Eugene de Villiers
eugene is on a distinguished road
What does the experimental data say?
From what information you provided I would guess the source of inconsistency is either the turbulence model or the wall function. Please post which turbulence models and wall options you used for Fluent and Foam. Also, what is your y+ value.
eugene is offline   Reply With Quote
Old   February 2, 2006, 10:51
Default hello thanks for your reply
atzaru
hello
1 - in both programs Foam and Fluent I used the basic k-epsilon equations
2 the standard wall functions based on launder and spalding is used in both cases (the same Constants E =9.0 and kappa=0.4187)
3 The same k-eps coeff have been used cmu=0.009, c1=1.44, c2=1.92. I do not know why in Foam we do not have Tke=1 and TDR=1.3 but a coeff alphaEps = 0.7692. What is this coeff?
4 The y+ is 24
5 For the moment i do not have experimental data to compare with.
It is strange i obtain so different results.
Old   February 2, 2006, 11:08
Default If you are using log the law o
Eugene de Villiers
If you are using log the law of the wall it is not valid at y+ = 24. My best guess is that fluent does something clever to improve at these intermediate values.
For Foam y+ needs to be around 100 with the standard k-epsilon model.
Old   February 2, 2006, 13:28
Default FLUENT has different requireme
Alberto Passalacqua
FLUENT has different requirements for its wall functions, according to its manual (30 < y+ < 60).
Also, in the OpenFOAM case files there is an error: in the 0\k dictionary the condition at the wall should be
wall
type zeroGradient;
instead of
wall
type fixedValue;
value uniform 0;
However it's strange that OpenFOAM 1.2 starts the calculation because it should quit and tell you the error.
Best regards,
Alberto
Alberto Passalacqua
Old   February 3, 2006, 05:01
Default Unfortunately/fortunately that
Eugene de Villiers
Unfortunately/fortunately that is one of the features of OpenFOAM. It allows you complete freedom in choosing individual boundary conditions, but at the same time, it wont tell you if you make an unwise choice.
Old   February 3, 2006, 10:04
Default Sorry, I wasn't clear. I disco
Alberto Passalacqua
Sorry, I wasn't clear. I discovered the error because trying to run the case with a grid I did, OpenFOAM 1.2 told me the problem in the BC ;-)
Regards,
Alberto
Alberto Passalacqua
Old   February 13, 2007, 14:42
Default Well... So the problem was jus
Cesar Belaunde Zarate
cesarbz is on a distinguished road
Well... So the problem was just de grid ? it's the same mesh for both programs?
Another questions...
What is the BC ?
And what represent de y+ value ?
thanks.
cesarbz is offline   Reply With Quote
Turbulent Flow in a Square Duct using LES Hock Ming FLUENT 0 February 7, 2009 20:25
Turbulence flow in a rectangular duct Watchapon Main CFD Forum 0 April 7, 2007 07:34
Turbulence Model for Rectangular Duct Flow ken FLUENT 4 May 26, 2005 20:39
3D rectangular duct flow UDF - urgnet Yogesh FLUENT 0 March 27, 2005 00:36
laminar viscous flow in a rectangular duct Bastian FLUENT 0 July 2, 2004 08:51
