November 6, 2006, 07:19 |
Hello
I have a problem with
Rolf Hansen
Hello
I have a problem with FoamX. We are 4 different users running OpenFOAM on a cluster headnode with different logon names. We are not able to run FoamX independently. A single user can open FoamX on the headnode, but as soon as another user attempts to open FoamX a mico exception occurs: uncaught MICO exception: IDL:omg.org/CORBA/INITIALIZE:1.0 (0, not-completed) ~/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 127: 23214 Aborted (core dumped) nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null Can anyone help me to make a workaround, or explain to me, how to set up FoamX, so the different users can work independently in FoamX. Thank you in advance Rolf Hansen |
November 7, 2006, 03:34 |
Check what your FOAMX_CONFIG i
Mattijs Janssens
Rep Power: 26 |
Check what your FOAMX_CONFIG is set to. Probably all point to the same central installation so the ns.ref file (which gets written there) gets corrupted.
Just copy the .OpenFOAM-1.3 directory to everyone's home directory. FoamX will detect this and use it instead as its config directory. |
November 8, 2006, 08:00 |
Hello Mattijs
We all use se
Rolf Hansen
Hello Mattijs
We all use separate installations of OpenFOAM. (Actually my colleague is running OpenFOAM-1.2, while I'm on the 1.3 version), so our $FOAMX_CONFIG is not pointing toward the same place (I checked it just to be sure!!). Best regards Rolf Hansen |
November 9, 2006, 02:48 |
Change the port number in $FOA
Mattijs Janssens
Rep Power: 26 |
Change the port number in $FOAMX_CONFIG/FoamXClient.cfg so they don't conflict?
November 13, 2006, 04:11 |
Now it works!!!
Thank you v
Rolf Hansen
Now it works!!!
Thank you very much |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem running FoamX | ianz8802 | OpenFOAM Installation | 11 | March 23, 2007 11:22 |
Running FoamX | vivekjoshi | OpenFOAM Installation | 0 | November 5, 2006 16:13 |
Running icoDyMFoam from FoamX | jdkummer | OpenFOAM Running, Solving & CFD | 3 | September 13, 2006 04:31 |
problem in running FoamX in Open FOAM | Gaurav | Main CFD Forum | 3 | May 10, 2006 05:06 |
