November 8, 2022, 02:14 |
Temperature initial conditions at wall
I am simulating air forced convection and conduction on a dummy human head using conjugate heat transfer with good results compared to experiment. I am trying to use buoyantSimpleFoam solver without the conduction to faster the solving time and I want to define the initial temperature at the head and let the convection cooling down. At the moment, I have difficulty with the bc to set an initial temperature different from internal fields that will be overwrite during time. In 0/T folder I am using the wall bc to fixedValue which is working but not what I want. I have tried fixedGradient with initial temperature, zeroGradient with initial temperature but it doesn't work. I know, it seems very easy to implement but I have yet not find the right way to do it and any help will be very helpful.
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
