Problem seeing new case in case browser
Old   October 10, 2005, 11:01
Default i`ve created a new case, but i
alan fergus
alan_fergus is on a distinguished road
i`ve created a new case, but i can`t see it in the browser, ran the refresh case browser but it still didn't come up. Any advice would be great
alan
alan_fergus is offline   Reply With Quote
Old   October 10, 2005, 13:57
Default If you look in the directory i
Mattijs Janssens
mattijs is on a distinguished road
If you look in the directory itself is the case created?
If not, maybe the protections on the directory prevent you from creating a directory.
Is this a standard solver (icoFoam, simpleFoam etc.)
mattijs is offline   Reply With Quote
Old   October 11, 2005, 09:36
Default thanks for the help. Got it so
alan fergus
thanks for the help. Got it sorted. This is a real noob question but when you are defining your boundary how do you work out the nfaces value and startFace value.
alan fergus
thanks for the help. Got it sorted. This is a real noob question but when you are defining your boundary how do you work out the nfaces value and startFace value. thanks alan
Old   October 11, 2005, 15:10
Default If you have a mesh, there is a
Billy
billy is on a distinguished road
If you have a mesh, there is a program called autoPatch which will create the patches automatically according to a specified angle. This has always worked for me after importing meshes from gmsh.
If you build you mesh in FoamX and use blockMesh I think you don't have to worry about nFaces abd startFace values.
It all depends on what you want to do.
billy is offline   Reply With Quote
Old   October 16, 2005, 07:31
Default Hi, I also started with usi
unoder
I also started with using the FoamX case browser but I wouldn't advise you to use that. I never use it now - instead you just copy from the tutorials/(solver) directory and modify your case directly with a text editor.
This works much better. And autopatch works from inside patchTool which you can invoke from command line. After that you just change initial conditions with your text editor inside the time= 0/ directory and/or modify whatever files in system/
As Billy writes, I don't think you have to worry about nFaces and startFace? At least I don't.
Old   June 19, 2006, 08:57
Default Hi, I have a 3D mesh from
newbee
I have a 3D mesh from gmsh which I have converted to foam. all seems fine except that I have a whole bunch of faces in defaultFaces. The attached picture ilustrates my converted my mesh. For this mesh I would like to have 6 patches as follows:
in picture:
closest patch = outlet
upper and right side = wall
curved holes = heat sources
left and bottom patch = symmetry
distant patch = inlet
unfortunatly I got a defaultPatch that containes all patches that are oriented in the depth direction and some in the outlet as follows:
defaultPatch:
here is my mesh file that I tried to convert:
Does someone know how I can get hold of or redefine the defaultPatch?
Thanks
/Erik
Old   June 19, 2006, 09:04
newbee
in picture:
defaultPatch:
Thanks
/Erik
Old   June 20, 2006, 02:27
Default With faceSet. See the sample f
Mattijs Janssens
With faceSet. See the sample faceSetDict.
There is a patchToFace source which allows you to pick up all faces of a patch.
Old   June 22, 2006, 03:46
Default Thanks, now I got the numbers
newbee
Thanks, now I got the numbers of the default face. How do I split it up and make new patches of it?
can I do this with the faceSet command also?
/erik
FoamX Case Browser holgerbre OpenFOAM Installation 4 March 30, 2009 04:19
Cloning a case or creating a new case for 16 processes mellanoxuser OpenFOAM Running, Solving & CFD 0 February 8, 2008 16:52
problem when I run the case Rui Siemens 1 February 1, 2007 06:25
I have a problem with the convergency of a case Raul Martin FLUENT 3 August 24, 2006 04:44
I have a Problem to create new Case lange OpenFOAM Pre-Processing 1 June 24, 2005 15:41
