BC for transonic converging-dinozzle
Old   June 11, 2009, 09:43
Default BC for transonic converging-dinozzle
Julian Krick
Julian K. is on a distinguished road
Hallo,
my configuration is the following: I want to simulate a convergent-divergent nozzle with M=1 in the throat and a shock in the divergent part of the nozzle. The flow in laminar. I have an inlet at the left side and an outlet at the right side. I want to initiallize the flow via a pressure difference between inlet and outlet. At the inlet there'll be just inflow, however, at the outlet it is likely to occur some reversed flow. This is okay for me.
So far so good, my problem is how to set the boundary conditions.
Pressure:
I'm pretty sure that I have to use 'fixedValue' at the inlet and at the outlet, since I want to initialize the flow via a pressure difference.
Velocity:
-Inlet: However, for the velocity at the inlet I found several BCs which could fit to my case; these are: 'zeroGradient', 'outletInlet', 'pressureInletVelocity', 'pressureInletOutletVelocity'
-Outlet: Also for the outlet I found tow BCs: 'zeroGradient' and 'inletOutlet'
Do you have any suggestion which BCs for the velocity at inlet/outlet are most suitable for my configuration?
Thanks for reading this thread.
Cheers,
Julian
grid generation: ICEM CFD 13.0
solver: CFX 13.0
Julian K. is offline   Reply With Quote
Old   July 3, 2009, 02:44
Default I m doing same proble
Abhishek
abhi is on a distinguished road
Have u got some thing ?
Please share how to set BC.
abhi is offline   Reply With Quote
DPM converging Problem Markus Alzon FLUENT 6 April 7, 2016 11:41
Solution not converging Alex FLUENT 5 April 14, 2015 00:55
TKE not converging ashishmgad FLUENT 0 April 17, 2009 01:34
K-E values not converging NK FLUENT 2 November 2, 2007 03:42
Energy eqn is nt converging.......plz help? preethi FLUENT 3 March 30, 2006 23:17
