scalarField inlet profile BC
Old   January 16, 2010, 11:09
Default scalarField inlet profile BC
Jan Potac
potac is on a distinguished road
Hi, I am trying to change parabolic velocity inlet BC downloaded from svn OF1.5-dev and obtain some scalar field (alpha,volume fraction) inlet profile instead. First, I thought that simple change in member function from vectorField::operator=vectorfunction(coord) to scalarField::operator= scalarfunction(coord) should be OK. But when compiling for OF1.6.x twoPhaseEulerFoam I receive an error: cannot call member function ‘void Foam::Field<Type>::operator=(const Foam::Field<Type>&) [with Type = double]’ without object.
Can someone help me to obtain a scalarField inlet profile BC, please? Maybe it is not the best way how to create such a BC.
The source BC files I use are attached. Thanks a lot!
Regards, Jan
potac is offline   Reply With Quote
Inlet Profile with CFX-Pre Fadi Ishak CFX 1 June 10, 2008 07:12
problem with velocity inlet profile file Duncan FLUENT 3 November 21, 2005 07:28
Create hemisphere like velocity profile at inlet Nelson Main CFD Forum 3 July 27, 2005 12:05
NON-UNIFORM VELOCITY INLET BOUNDARY PROFILE MURAT Main CFD Forum 0 December 30, 2003 21:08
create logarithmic wind profile for inlet Murat Main CFD Forum 0 December 30, 2003 00:45
