Simulation of waves on a Water Surface
Like Tree1Likes
Old   December 12, 2011, 17:20
Default Simulation of waves on a Water Surface
Pierre
Leech is on a distinguished road
Hi anyone,
my natural language is not english, so I hope i can still describe my problem.
What i want to do is to build a OpenFoam-Model which consists of a rectangular prism. The bottom half is filled with water, the top half with air.
So far I am able to do it.
Now I got 2 questions:
-The Air on Top is supposed to flow in a distribution. What i mean is that the air shall be injected with high speed on top of the prism and with low speed near the water surface (pretty simular to a boundary layer in big).
-The water shall be moved by the walls of the prism. For example one wall is oscillating in a sinus-shape or a wave-function so that waves will get build on the water surface.
Actually i got no idea how to build this model.
Any help would be appreciated.
I hope my english isnt that horrible, that nobody understands what I'm trying to ask.
Thanks a lot!
Leech is offline   Reply With Quote
Old   December 18, 2011, 14:50
Nima Samkhaniani
nimasam is on a distinguished road
hi pier
could you tell me in which part you face the problem?
i didn't get what you are going to model, however if you want to have interface and see water surface you can use interFoam, if you want to make nonuniform boundary condition you should use a utility called groovyBC ( you can find it in wiki)
nimasam is offline   Reply With Quote
Old   December 18, 2011, 18:52
Pierre
hi,
i allready found the swak4foam library and succesfully installed it.
So what Im trying to do right now, is to create a box and fill it half with water. (Used with InterFOAM later with InterDymFoam, so ill use the setfieldsdict to fill it).
My only trouble right now is if ill get the groovy bc to work and to make some waves for me. But well see that.
Other question is: At the bottom half of the box ill use groovy bc to get waves into the water. At the top half i want to inject the wind (air in a distribution as described before). For that surpose i created 2 boxes right on top of each other, so i can insert 2 bc's (top-air inlet bottom-groovybc). Will this work? When the water gets waving itll move over the bottom box. What will the air inlet do to the waterwaves in front of it?
Thanks!
Old   December 19, 2011, 01:56
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Pierre
Since you are going to generate waves, you might be interested in looking into waves2Foam (http://openfoamwiki.net/index.php/Contrib/waves2Foam). It is not straight forward applicable for your problem, since there has been given no thought for the velocity field in the air. However, if you change the waveVelocityFvVectorPatchField.* files, then I suppose you should be able to achieve what you describe.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   December 19, 2011, 02:25
Nima Samkhaniani
Originally Posted by Leech View Post
hi,
Thanks!
you can apply different BC in different position of a patch, just by groovyBC, in other words you dont need to creat two box at all,
if you look in groovyBc tutorials in wiki you will find some examples about it
Old   December 19, 2011, 04:43
ngj
Hi Pierre,
One more consideration with respect to the problem you describe. The solver 'interFoam' produces considerable velocities in the air, which originate from numerical inaccuracies, so you should be very careful, if you are thinking of using interFoam to study the effect of wind on the shape and other properties of surface water waves.
Good luck,
Niels
gregjunqua likes this.
Old   December 19, 2011, 10:39
Pierre
Originally Posted by ngj View Post
Hi Pierre
Kind regards,
Niels
Thanks, ill take a look at that!
Old   December 19, 2011, 10:41
Pierre
Hi Pierre,
Good luck,
Niels
good to know about these limitations. But i guess these wont bother me too much. The goal ist to place a floating object on the water, the wind ist just there to make the sea-simulation a bit more complete. I dont think that the wind effect on the water surface is important.
Old   December 19, 2011, 10:50
Pierre
thanks for that tip. But what function exactly is it that is able to place different BC's on one face? Can't find it in the wiki
Old   December 19, 2011, 10:58
Pablo Higuera
Phicau is on a distinguished road
Hi
http://openfoamwiki.net/index.php/Co...groovyWaveTank
   inlet
       type            groovyBC;
       valueExpression "(pos().z<=A*cos(-w*time())+0.5*k*A*A*cos(2*(-w*time()))) ? vector( A*w*exp(k*pos().z)*cos(-w*time()), 0, A*w*exp(k*pos().z)*sin(-w*time())) : wind)";
       variables       "l=5;A=0.1;g=vector(0,0,-9.81);k=2*pi/l;w=sqrt(k*mag(g));wind=vector(0,0,0);";
       timelines       ();
Just change "wind" components to what you need.
Phicau is offline   Reply With Quote
Old   December 19, 2011, 11:07
Pierre
Originally Posted by Phicau View Post
Hi
   inlet
       type            groovyBC;
       timelines       ();
I'm sorry but i don't get it
Where do you define that the wind is on the upper half of the patch and that the wave is on the lower half of the patch? Or are both of these functions intersecting over the complete patch?
Thank you so much!
Old   December 19, 2011, 11:16
Pablo Higuera
each time step it generates waves (alpha1=1) for cells with centers below the calculated eta, with the prescribed velocity.
Otherwise (what lies over it) gets alpha1=0 (air) and sets velocity to vector(0,0,0) on the original code. I changed that to define variable "wind", which is basically the same now, as it is set to (0,0,0). But you can modify that to introduce wind.
For example, wind=vector(1,0,0); will produce 1m/s of wind in the x direction.
Regards
Old   December 19, 2011, 11:20
Default groovyBC
  #13
Nima Samkhaniani
let me simplify with an example:
consider you have a vertical face with the height of 1m
and your interface is in a position 0.5 so pos().z > 0.5 is air and pos().z < 0.5 is water
now you should change your boundary condition in file alpha and U to groovy BC
then in alpha file you should define which portion of face is water and which portion of it is air , some thing like this
valueExpression "pos().z>0.5 ? 1.0 : 0)";
and in U
valueExpression "vector(pos().z>0.5 ? a : b,0,0)";
instead of a and b you should implement your function
i hope you get the whole idea!
Old   December 19, 2011, 11:22
Pierre
I think i got it now!
Thank you all so much. I'll try to get it working
Old   December 19, 2011, 13:50
Default sampling forces from one phase only
  #15
musaddeque hossein
musahossein is on a distinguished road
Dear All:
In sampleDict is there any way to measure pressure due to one phase only (eg water and not the air above it?). I am trying to sample pressure forces on the left and right wall of a 2D tank using interDyMFoam. I get pressure at cell / cell point along the vertical face of the left and right walls. The tank is half full of water, with air in the top half of the tank. I am only interested in the pressure from the water. Can this be done?
Thanks
musahossein is offline   Reply With Quote
Old   December 20, 2011, 15:41
Pierre
Hey Anyone,
i still could use some help!
I am actually creating the tank with the groovy BC as you informed me.
I got some problems now (to find the problems i attached my wavetank-Folder):
-BlockMesh work fine (...)
-When I type setFields OpenFoam says :"Couldnt find value expression on inlet" for both U and alpha1. I tried to add value uniform 1 oder value uniform (1 0 0) and then it worked but I am not shure if these are ok? Why he asks me to add this line?
-I got no outlet somewhere. And I am using p_rgh. In the GroovyWaveTank-Tutorial they were using pd with an athmosphere. I am a bit confused what i need to do to create a athmosphere? (which i want to have)
-What conditions do I have to give to the walls, so that the waves transmitted from the inlet just go trough and do not rebound?
-When i am trying to run InterFoam he says: "Unknow BC at Inlet GroovyBC". But i installed the swak4foam library and i allready runned some of the examples and they worked?
So much questions...
Thank you all
Greetings
Old   December 20, 2011, 15:51
Pierre
and in U
With "your function" you mean the function for the wind injection?
I just wrote 1,0,0 in the attached pack in the previous post, because the vector wind is also 1 0 0? Or did i missunderstood something?
Old   December 20, 2011, 17:15
Nima Samkhaniani
two many questions
1) i suggest to use funkySetFields instead of setFields (find in wiki)
2) add this line into your controlDict
libs ("libOpenFOAM.so""libgroovyBC.so");
3) if air injection is uniform then it would be constant but you have chance to choose any function or distribution for air injection
Old   December 20, 2011, 18:21
Pierre
two many questions
to 1) what would be the difference or the benefit?
to 2) ill try that tomorrow, thanks!
to 3) where is that function added? at a:b? what type of function can i write there?
to x) whats about the error of setFields "need to add value"?
Thanks!
Old   December 21, 2011, 00:36
Nima Samkhaniani
to 1 and x ) use the funkySetFields you will find its great benefits
to 2) first try then, if you face problem, ask again
3)a or b should be replaced with your function )
for example you can use this function sin (pos().z), i didnt know what function was suitable for your simulation so i remained it for your modification
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 20:13
CFD Animations of waves, ships, and turbulence---- Douglas Dommermuth Main CFD Forum 23 January 8, 2008 12:41
CFX bubble simulation with free surface model adma CFX 6 February 3, 2006 11:17
spherical balls in water with free surface Karthick FLUENT 0 February 10, 2004 04:24
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
